Router Switch - Carpentry - DIY Chatroom Home Improvement Forum
Old 08-21-2011, 04:03 PM   #1
Router switch
I inherited a router fixed to a table. All is well apart from the fact that the on switch needs depressing constantly whic would br fine if used as a plunger router by hand not in a table, when using on the table I loose one hand to keep the switch pressed. Am I missing a control which allows this machine to stay on ? It's a new something or other is the brand name , not an expensive one.
landed is offline   Reply With Quote
Old 08-21-2011, 04:05 PM   #2
http://www.routerforums.com/table-mo...er-switch.html
Old 08-21-2011, 08:13 PM   #3
Rewards Points: 5,336
Router tables I've seen have the router switch in the "on" position all the time. The router is turned on and off by a standard light type switch on the table. If you can't get the router switch to stay on, get a replacement from the router manufacturer.
What brand is the router?
Ron
B. Franklin 1759
Wiring in a 4-way Switch RickSene Electrical 6 05-13-2017 04:29 PM
Carrier Infinity 69 Trouble Code 42 bodya1 HVAC 4 12-05-2010 06:43 PM
Wiring 2 light fixtures to same switch and add outlet RyanS2000 Electrical 13 10-10-2010 02:17 AM
3-way light with a twist Jeepsail Electrical 14 05-18-2010 01:24 AM
4 way switch confusion Richo Electrical 10 04-09-2009 07:11 AM
