Router Edge - Carpentry - DIY Chatroom Home Improvement Forum
Old 07-04-2013, 02:05 PM   #1
CitadelBlue's Avatar
Rewards Points: 97
Router edge
I'm looking at doing this edge on a cut piece of 1"x1" to finish off the bottom edge of my kitchen cabinets. Can I buy a router bit to do this edge, do I need to use a table saw blade, get out my pocket knife and so some carving or what??????
CitadelBlue is online now   Reply With Quote
Old 07-04-2013, 04:06 PM   #2
DIY staff
Rewards Points: 7,174
That should be a store bought shape---Go to one of the router bit sites and see if you can find a match---you will not find that one in a Home Depot---
Old 07-04-2013, 04:26 PM   #3
Rewards Points: 97
Looks like its a "3 bead edge"
http://www.docstoc.com/docs/74490809...-PROFILE-CHART
Old 07-04-2013, 04:40 PM   #4
DIY staff
I have the worlds worst memory for names----but I believe I have that profile--so it is fairly common----Jim or Woodworkbykirk might know---
Old 07-04-2013, 05:27 PM   #5
Rewards Points: 13,228
Any box store should have that as a stock molding.
Old 07-04-2013, 05:54 PM   #6
journeyman carpenter
woodworkbykirk's Avatar
Rewards Points: 1,058
you might get something similar but not exact. i cant get that profile at a big box store or at my trim supplier.. its definitely something youd need a shaper for or atleast shaper knives outfitted on a table saw. it can be done on a router table but it would require quite a bit of setup time and several passes
woodworkbykirk is offline   Reply With Quote
Old 07-04-2013, 05:57 PM   #7
kwikfishron's Avatar
Rewards Points: 172
This is as close as I could find. http://www.toolstoday.com/p-5241-var...uter-bits.aspx
kwikfishron is online now   Reply With Quote
Old 07-04-2013, 11:03 PM   #8
Rewards Points: 97
Originally Posted by kwikfishron View Post
Ding .... Ding........ Ding ....... We have a winner
Old 07-05-2013, 03:42 AM   #9
JOATMON
ddawg16's Avatar
Rewards Points: 1,110
The bit will cost more than the molding....
ddawg16 is online now   Reply With Quote
Old 07-05-2013, 11:39 PM   #10
Rewards Points: 97
mlcswoodworking.com, item #8799 ($25.00 and shipping is free.................)
Old 07-06-2013, 12:54 AM   #11
JOATMON
ddawg16's Avatar
I'll have to check out that web site...I don't think I've ever paid less than $35 for a large bit
Old 07-06-2013, 06:39 AM   #12
Rewards Points: 172
That's not the Variable Beading bit though.
Old 07-06-2013, 10:51 AM   #13
Davejss's Avatar
Rewards Points: 740
When I need to exactly replicate a molding I take a piece of step flashing or other scrap tin and trace the profile onto it. Then I cut along the lines with my tin snips and fine tune it with a file. Bring it to a tool maker and have him make a cutter for my molding machine.
He can bang one out on his milling machine in a couple of minutes, and its cheaper than buying a router bit, assuming you can find one to match. Of course my cutters are made from HS steel and not carbide, but I rarely need to mill up enough stock to need the durability of carbide. Plus HS steel sharpens quickly if needed.
Davejss is offline   Reply With Quote
How to create hinge mortise on bevelled hinge edge using a router & jig? Toronto Carpentry 20 07-29-2012 11:53 AM
Drip edge under felt Jeoroc24 Roofing/Siding 1 09-07-2011 11:40 PM
router problem boman47k Networking 4 04-12-2011 07:07 PM
Router Advice diyheroe Carpentry 0 09-24-2010 10:09 AM
Shingle Installation with F5S Standard Drip Edge ShortEdged Roofing/Siding 32 02-15-2008 03:10 PM
