-   -   Router edge (http://www.diychatroom.com/f14/router-edge-183046/)
CitadelBlue 07-04-2013 02:05 PM
Router edge
1 Attachment(s)
I'm looking at doing this edge on a cut piece of 1"x1" to finish off the bottom edge of my kitchen cabinets. Can I buy a router bit to do this edge, do I need to use a table saw blade, get out my pocket knife and so some carving or what??????
oh'mike 07-04-2013 04:06 PM
That should be a store bought shape---Go to one of the router bit sites and see if you can find a match---you will not find that one in a Home Depot---
CitadelBlue 07-04-2013 04:26 PM
Looks like its a "3 bead edge"
http://www.docstoc.com/docs/74490809...-PROFILE-CHART
oh'mike 07-04-2013 04:40 PM
I have the worlds worst memory for names----but I believe I have that profile--so it is fairly common----Jim or Woodworkbykirk might know---
joecaption 07-04-2013 05:27 PM
Any box store should have that as a stock molding.
woodworkbykirk 07-04-2013 05:54 PM
you might get something similar but not exact. i cant get that profile at a big box store or at my trim supplier.. its definitely something youd need a shaper for or atleast shaper knives outfitted on a table saw. it can be done on a router table but it would require quite a bit of setup time and several passes
kwikfishron 07-04-2013 05:57 PM
199 Attachment(s)
This is as close as I could find. http://www.toolstoday.com/p-5241-var...uter-bits.aspx
CitadelBlue 07-04-2013 11:03 PM
Originally Posted by kwikfishron (Post 1211663)
Ding .... Ding........ Ding ....... We have a winner
ddawg16 07-05-2013 03:42 AM
The bit will cost more than the molding....
CitadelBlue 07-05-2013 11:39 PM
mlcswoodworking.com, item #8799 ($25.00 and shipping is free.................)
ddawg16 07-06-2013 12:54 AM
I'll have to check out that web site...I don't think I've ever paid less than $35 for a large bit
kwikfishron 07-06-2013 06:39 AM
199 Attachment(s)
That's not the Variable Beading bit though.
Davejss 07-06-2013 10:51 AM
When I need to exactly replicate a molding I take a piece of step flashing or other scrap tin and trace the profile onto it. Then I cut along the lines with my tin snips and fine tune it with a file. Bring it to a tool maker and have him make a cutter for my molding machine.
He can bang one out on his milling machine in a couple of minutes, and its cheaper than buying a router bit, assuming you can find one to match. Of course my cutters are made from HS steel and not carbide, but I rarely need to mill up enough stock to need the durability of carbide. Plus HS steel sharpens quickly if needed.
