Router Bit Choice For Window Stool - Carpentry - DIY Chatroom Home Improvement Forum
Old 01-12-2011, 05:02 PM   #1
router bit choice for window stool
I am going to be insalling new window stools and would like some ideas on which type of router bit to use to put on the outer edge. I'm not looking for anything too fancy, I saw some bits a HF today but was unsure of the style to get. The wood will be painted white and probably 1x4 or 1x5 in size. Thanks in advance.
RobertN is offline   Reply With Quote
Old 01-12-2011, 06:01 PM   #2
Residential Designer
AndyGump's Avatar
Rewards Points: 664
Send a message via Skype™ to AndyGump
In my opinion you should use a thicker material for the stools. Use a 5/4 or 6/4 material, read (five quarter, six quarter). They will be about 1-1/16" and 1-5/16" thick materials.
Use a simple ogee bit in a 1/2" shank.
Andy.
AndyGump is offline   Reply With Quote
Old 01-12-2011, 07:11 PM   #3
Ole Wood Worker
BigJim's Avatar
Rewards Points: 202
If you want something simple that will good I would go with a round over bit and run it top and bottom of the stool to make it a nosing.
New members: Please consider adding your location to your profile.
If you do what you've always done, you'll get what you've always got.
http://www.woodworkingtalk.com/forum.php
Jim
BigJim is online now   Reply With Quote
Old 01-12-2011, 08:44 PM   #4
I used a Bosch 1/2'' cut Roman ogee on 1x poplar then painted it white and it looks excellent.
lucasrcole is offline   Reply With Quote
Old 01-13-2011, 01:45 PM   #5
uva uvam vivendo variafit
WirelessG's Avatar
Rewards Points: 698
I agree with jiju. Your trim under the sill will probably be a 399 or something shaped that will add detail to the look.
WirelessG is offline   Reply With Quote
Old 01-14-2011, 08:35 AM   #6
Household Handyman
Rewards Points: 1,408
Errr, maybe different areas of the country, but around here we can buy three different sizes/styles of window stool. Just cut to length, and fit to window opening per se. I have three (3) to do next week on one house, dog chewed them up.
Window stool and framing Joe1. Building & Construction 24 11-21-2010 10:54 PM
Router Advice diyheroe Carpentry 0 09-24-2010 10:09 AM
Router Table gmhammes Tools 8 06-27-2010 11:32 AM
Need help for window stool plannng creamaster Carpentry 2 03-28-2010 04:12 PM
What router bit is used to create the inside angle on a window stool? Mikedks Building & Construction 7 05-12-2008 05:43 PM
