Router Base Plates - Carpentry - DIY Chatroom Home Improvement Forum
Old 02-23-2010, 12:04 PM   #1
Router base plates
I have used a table mounted router (Dewalt 618) for 2-3 years and can get most of the results I want. I recently tried to use the router as hand held, and after the assembly realized the 1/2 " radius bit did not fit through the openning in the base plate. Dewalt only has one base plate available. Is there a source for base paltes with larger opennings, or do I have to get a base feom Rocklers and drill out as needed?
4cedars1 is offline   Reply With Quote
Old 02-23-2010, 02:11 PM   #2
May not be what you need but if there is a Lowe's close they are closing out some Milescraft offset router bases which look like they will fit a lot of different router. Half priced at 9.98. Picked one up today along with some Bench Dog feather boards on clearance also.
Mike in Arkansas is offline   Reply With Quote
Old 02-23-2010, 02:39 PM   #3
Rewards Points: 5,336
Go to www.patwarner.com for router accessories.
Ron
Old 02-23-2010, 06:03 PM   #4
DIY staff
Rewards Points: 7,174
Porter Cable has the same trouble----I just enlarged the hole on a spare base plate.
Old 02-23-2010, 07:29 PM   #5
remodeling pro
Not sure about Dewalt, but PC bases with oversize hole (I think it is 2-1/2") is pretty common, I think even HD has them.
But I generally don't worry about the base plate,they are cheap enough, so I have a couple with different size holes where I just ran the bit through them.This gives maxinum support, and helps prevent the router from tipping when an oversize hole passes over the end of the stock.
troubleseeker is offline   Reply With Quote
Shower base problem Gregor24 Plumbing 3 01-15-2010 09:34 PM
How to tile around a Pre fab shower base geoffthemonk Building & Construction 1 11-07-2009 09:10 AM
How to create a curved wooden base shoe? hayzen Carpentry 3 07-28-2009 03:29 PM
Shutoff switch for custom Router Table. mfleming Electrical 14 11-13-2008 12:50 PM
The case of the hanging base plate KaiserS Building & Construction 4 02-02-2008 06:42 PM
