Go Back   DIY Chatroom - DIY Home Improvement Forum > Home Improvement > Carpentry
Old 01-17-2008, 05:18 AM   #1
router
I have a router and the router bits. The instructions tell me how to use the router, how to attach the bits etc but as I have never used a router I have no idea what each bit does and how to use it. Is there a site I can look up or a book I can buy that will show me what each bit does. I am a visual person and need to see what the result is.
Thanks for your help
Irwinbuilt
irwinbuilt is offline   Reply With Quote
Old 01-17-2008, 07:22 AM   #2
Master General ReEngineer
Bondo's Avatar
router
Ayuh,.....Find some scrap wood,+ Have at It.......
The router Bit will leave an exact Inverse copy of itself in the wood......
Old 01-17-2008, 10:05 AM   #3
router
I really believe you should find a knowledgeable person to get you started PROPERLY. Just by your question, you are not ready to tackle a router just by reading. Your are going to SEVERELY hurt yourself or someone else.
Try your local lumber yard (not big box type) or a cabinet maker in the area. Invest a few dollars in their knowledge & experience...it could save your eye or definitely a few fingers.
JGarth is offline   Reply With Quote
Old 01-17-2008, 05:14 PM   #4
www.handyguyspodcast.com
router
Norm Abram had a two part show entitled Router 101 a year or two ago. It was pretty good. Did not show you every possible router bit but it did walk you through the standard bits and routing methods. Check it out at:
http://www.newyankee.com/getproduct.php?0606
borninpa is offline   Reply With Quote
Old 01-18-2008, 09:22 AM   #5
Woodworker and Contractor
Kingfisher's Avatar
router
These may help
http://www.youtube.com/results?searc...&v=fURo3TshnkQ
If your in Tampa FL pm me and I'll show you how to use one in my shop one day
Kingfisher is offline   Reply With Quote
Old 01-20-2008, 08:22 AM   #6
router
Thank you for your replies I went to the local library and got out some books but I find that I really need to be shown. Unfortunately if I approach a man he seems to prefer to actually do the job then show me 'how it is done' but I will try to approach perhaps a wood work group.
Irwinbuilt
CMT Router Bits HAASEMAN2003 Tools 4 01-16-2008 09:01 PM
what size router bit for this job... KUIPORNG Remodeling 3 10-17-2007 03:00 PM
Router safety majakdragon Safety 7 09-21-2007 08:28 AM
Router Guide powrus Tools 2 05-02-2006 06:25 AM
