Round Corner Drywall - Carpentry - DIY Chatroom Home Improvement Forum
Old 08-19-2011, 04:55 PM   #1
How do I install baseboards on rounded drywall corners?
johnsml is offline   Reply With Quote
Old 08-19-2011, 05:43 PM   #2
Tileguy
Bud Cline's Avatar
Rewards Points: 558
There are several ways to deal with that stuff.
Rounded drywall corner beads come with the bottom portion squared off to accommodate standard base.
Or you can buy the squared corners to use in conjunction with the rounded corner bead.
You can also by wooden rounded base corner profiles.
You can also install blocks on all of the out-corners that will allow the base to be straight-cut.
You can also ignore the round and install the base mitered to a corner then fill the resulting hole with caulk. (Seen it done.)
You can also stop the base short of the radius and do a return to the wall using the base profile for the return.The corner bead is then neatly finished to the floor.
XXX
Old 08-19-2011, 06:20 PM   #3
kwikfishron's Avatar
Rewards Points: 586
Don’t stop there, there’s still at least one more.
kwikfishron is offline   Reply With Quote
The Following User Says Thank You to kwikfishron For This Useful Post:
Willie T (08-19-2011)
Old 08-19-2011, 06:21 PM   #4
Tileguy
Bud Cline's Avatar
Rewards Points: 558
That's all I could think of. Feel free to add to the list.
XXX
Old 08-19-2011, 06:37 PM   #5
Rewards Points: 586
Making your own, two at a time. 15deg glued up around a dowel with a rubber band.
I do like the blocks better though.
Old 08-19-2011, 06:59 PM   #6
Tileguy
Bud Cline's Avatar
Rewards Points: 558
That reminds me...
I have also seen a small mitered piece used at the corner. A piece maybe 1" wide mitered to 22.5 degrees on both sides to match a longer piece of base also mitered at 22.5.
XXX
Old 08-19-2011, 08:09 PM   #7
Old School
Willie T's Avatar
That reminds me...
This is the standard way of doing it around here.
Here is the measurement at the inside (back) of the baseboard (for the little piece) for a 3/4" radius corner. (3/4" radius for the d/w rounded corner is pretty standard) I show the inside because no matter how thick or how intricate the front of the baseboard is, the measurement on the back of the baseboard shown here will always remain constant. For a 3/4" radius, it will be right at 5/8", depending on how careful or how sloppy the d/w finishers were. To be honest, you're probably safer to make it a taste bigger because most d/w guys get pretty careless down there at the bottom of a wall, and usually load it up with too much mud.
(Ignore the last photo on the lower right... the one with the brown piece. It was just in the picture, and I didn't feel like cropping it out.)
Willie T
Old 08-23-2011, 01:32 AM   #8
yep that's what I do, segmented pieces at 22.5, corner pieces are usually around an inch or so. Find this works pretty well.
chrisBC is offline   Reply With Quote
Vinyl siding corner posts and flashing on dormers rhastler Building & Construction 7 06-05-2009 10:08 PM
Drywall Inside Corner Tool? helpless handyman Drywall & Plaster 24 02-19-2009 06:02 PM
Anybody install or own a CORNER kitchen sink? Also RTA cabs... matermark Kitchen & Bath Remodeling 2 01-24-2009 05:41 PM
drywall corner bead drewhart Drywall & Plaster 2 10-22-2008 09:28 AM
Corner Bead for Drywall? sandyman720 Building & Construction 10 10-10-2007 10:17 AM
