Round Corner Baseboard Piece - Carpentry - DIY Chatroom Home Improvement Forum
Old 11-23-2011, 09:45 PM   #1
Round Corner Baseboard piece
Hello -
I've searched all over the internet for a baseboard piece to my rounded drywall corners and am unable to find. Does anyone know where I can get replacement pieces? Are there online suppliers?
See pictures...
Round Corner Baseboard piece-photo-1.jpg   Round Corner Baseboard piece-photo-2.jpg   Round Corner Baseboard piece-photo-3.jpg   Round Corner Baseboard piece-photo-4.jpg   Round Corner Baseboard piece-photo-5.jpg
b1021 is offline   Reply With Quote
Old 11-23-2011, 09:49 PM   #2
Rewards Points: 150
Square off the bottom with plaster then install normally.
OhioHomeDoctor is offline   Reply With Quote
Old 11-23-2011, 10:51 PM   #3
I have a whole house full of these. Don't think I want to have non matching baseboards.
Old 11-23-2011, 11:08 PM   #4
Tileguy
Bud Cline's Avatar
Rewards Points: 558
Why wouldn't you just go to a local lumber yard and buy them off the shelf. Those things are common these days, you can find them almost everywhere.
Don't even think about squaring-off the corners, that's a goofy idea.
Old 11-23-2011, 11:10 PM   #5
Don't even think about squaring-off the corners.
Thanks! Yes, I thought it would be simple, but I went to home depot and lowes and they were no help..looked around the net and couldn't find anything. I'll check some lumber yards.
Old 11-24-2011, 05:21 PM   #6
journeyman carpenter
woodworkbykirk's Avatar
Rewards Points: 1,062
its possible to make the corner with the baseboard you already have, but it has to be done in several peices.. if your baseboard is a specific molding you'll have to try to get a match from the company that makes it..other wise make a series of very short peices which make the turn.
i have to do it every now and then on larger bullnose corners. i have a contact who is a published trim specialist. he does it with a combination of plaster and autobody resin. he uses a 10" drywall knife and shapes the blade to match the trim exactly. its a very tricky process, not diy but it looks sharp
woodworkbykirk is offline   Reply With Quote
Old 11-24-2011, 07:42 PM   #7
You can get the molding from Carolina trim in north Carolina. Google them, they should have a website. They carry almost all moldings in stock in flexible paint and stain grade.
Jmdesign is offline   Reply With Quote
Old 11-24-2011, 08:07 PM   #8
Tileguy
Bud Cline's Avatar
Rewards Points: 558
b1021: "I have a whole house full of these. Don't think I want to have non matching baseboards."
Old 11-24-2011, 09:47 PM   #9
????, boosting your post count bud?
Old 11-24-2011, 09:52 PM   #10
Speaking about baseboards can one paint over baseboards that have been stained?
Chavezday is offline   Reply With Quote
Old 11-24-2011, 10:56 PM   #11
Rewards Points: 5,336
Just stained wood is easy. Just prime and paint. If there's a polyurethane finish over the paint, you will need to sand the baseboard first, then prime and paint.
Ron
B. Franklin 1759
Old 11-24-2011, 11:34 PM   #12
Tileguy
Bud Cline's Avatar
Rewards Points: 558
Not at all!!!
Use your head man!
Why would the guy want to have one jack-leg corner when he has an entire house done the other way. He didn't come here asking for an alternative method - he came here asking where to find replacements for what he already has a whole house of.
Old 11-25-2011, 04:52 PM   #13
what im saying is that they cant find the peice, it can be made. ive had to do it. ive trimmed many houses where we cant find a match to existing trim so it takes some creative cutting on the mitre saw or some time on a router and table saw.
i dont know how many times ive had to make things from scratch both by making multiple passes on teh table saw or by using multiple router bits to create a match
The Hows and Whys of Furring Strips. Part-1 Willie T How To Guides 12 03-01-2013 03:58 PM
crown molding fitting problem momof2labs Carpentry 16 10-15-2011 01:45 PM
Baseboard or Quarter Round for Laminate Floor sweaty General DIY Discussions 10 08-03-2011 05:15 PM
Vinyl siding corner posts and flashing on dormers rhastler Building & Construction 7 06-05-2009 11:08 PM
Quarter round and baseboard justtired Flooring 1 09-30-2006 05:39 PM
