Rough Opening Issues For Interior Pre-hung Door - Carpentry - DIY Chatroom Home Improvement Forum
Old 04-03-2009, 02:53 PM   #1
Rough Opening issues for interior Pre-hung door
My first question is when framing a rough opening 82 1/4" height for a pre-hung door do I need to take into account the type of flooring that will be installed later? On one of my doors there will be std hardwood flooring installed in that area. Is it still OK to rough out the 82 1/4 off of the bare concrete floor prior to the install of the hardwood?
2nd question: On another door I have to frame under a support beam and will not have the 82 1/4. At best I will have 80 1/4. I assume this is no big deal, just trim off 2" from the bottom of the pre-hung jam and door?
Thanks folks you have already been a great help!!!
get2bill is offline   Reply With Quote
Old 04-03-2009, 03:13 PM   #2
47_47's Avatar
Rewards Points: 44
Do you know the additional height of your finished floor? If so add that to the 82". Most prehung doors have a large gap from the bottom of the door to the frame. This looks terrible when over a hardwood or tile floor. I usually cut the side jambs to close this gap and add 1/4" from this length for my RO.
Yes for 2", I'd cut the bottom of the door. If you have a hollow core door you may cut off the bottom spacer and have to glue it back in. Because you cut the bottom, you lowered your door and this door knob will be lower than the rest.
Added: I just reread your post and you are putting this over concrete. Hold your jambs off of the concrete by 1/2".
47_47 is offline   Reply With Quote
Old 04-03-2009, 03:45 PM   #3
Registered User
Rewards Points: 5,216
Don't forget the sub-floor or cleat thickness. Pre-hung doors are shorter than the jambs for ease of install when house is heated/cooled by forced-air, that gap acts as a return air path for that room. Otherwise it could help to un-balance the HVAC system. Building inspectors do check for this. Be safe, GBAR
Old 04-04-2009, 08:27 AM   #4
you could put the doors in after the flooring is finished ( un less its carpeting ) your floor guys would appreciate that. Make sure to check the level over the threshold before you cut the jambs.
II Weeks is offline   Reply With Quote
Larson Storm Door Won't Close Snowbird Building & Construction 13 03-03-2009 04:01 AM
Rough opening for door is 1/4" too small-what to do? Badfish740 Building & Construction 15 02-08-2009 11:05 PM
Pre Hung Door Issue! bmster Carpentry 8 03-11-2008 08:31 PM
Entry Door---My Story----Advice Please rossmoor Building & Construction 3 02-29-2008 10:13 PM
