Rotting Under Exterior Door Frame - Carpentry - DIY Chatroom Home Improvement Forum
Old 08-11-2008, 01:30 PM   #1
Rotting under exterior door frame
I went to replace my exterior metal door which had rusted into oblivian.
When I removed the old frame, the entire underneath was all a mess of rotted wood. While I'm reluctant to put another piece of wood there (perhaps treated) does it make any sense to concrete under it or might that be a bad idea?
diyninja is offline   Reply With Quote
Old 08-11-2008, 02:32 PM   #2
the Musigician
DangerMouse's Avatar
what is under the rotted wood? ground? foundation? cement in contact with the ground will wick moisture and rot any wood it touches. if you post pics it helps a lot here i've found. =o)
DM
Rotting door jamb bob22 Building & Construction 4 07-04-2008 11:14 AM
Celebration FL home rotting - HELP Celebration Homeowner General DIY Discussions 4 06-14-2008 07:27 PM
Exterior trim paint is peeling, wood is rotting! firsthomenewb Painting 10 05-15-2008 05:04 PM
Rotting Rim board baianodiy Building & Construction 1 11-10-2007 07:11 AM
Concrete deck -- rotting floor joists jwill Building & Construction 6 09-05-2007 08:01 AM
