Rotten Wood Windows - Where To Begin - Carpentry - DIY Chatroom Home Improvement Forum
Old 03-17-2014, 04:14 PM   #1
Rotten Wood Windows - Where to begin
I just got the kitchen back together after gutting to the studs and now need to tackle this window issue. The house was built in early '30s. While pulling a window shut in one of the bedrooms, the bottom broke loose due to some pretty severe rot. The only window experience I have is writing a check to have them replaced in another house, but I have the time, tools, desire and ability to learn whatever is necessary here. Just looking for some insight.
Mark
machouinard is offline   Reply With Quote
Old 03-17-2014, 04:29 PM   #2
Rewards Points: 13,300
Time to measure and order measure and order new replacement windows.
Expect about 10 days to get them.
Simple DIY job.
Directions to install will come right on the windows.
I buy all mine from my siding suppliers. Not some box store.
Simonton and Windcor are the two windows I use.
woodworkbykirk (03-18-2014)
Old 03-17-2014, 04:31 PM   #3
Time for new replacement windows.
Old 03-17-2014, 04:39 PM   #4
http://www.doityourself.com/stry/how...cement-windows
Old 03-17-2014, 09:21 PM   #5
Gymschu's Avatar
Rewards Points: 490
Wow, those windows really are TOAST! Follow Joe's advice.
Gymschu is online now   Reply With Quote
Old 03-17-2014, 09:57 PM   #6
Thanks for the replies everyone. I'm assuming what this is going to take, best case scenario, is cutting the wall out around the frame, hoping to find no interior rot, and installing new windows in existing frame ( or is it called casing? ). Bad case scenario, rot has spread to the frame and that will need to be replaced also - I suspect this is true. Worst case, guess that depends on how much moisture got through and for how long, right?
Old 03-18-2014, 12:34 AM   #7
I'm not seeing any rot in the sill or the jambs in that picture. Poke it with a screw driver.
Just opening up a big can of worms replacing the whole window when your working around stucco.
You could replace both of those windows with replacement windows in less then an hour.
It's all done from the inside.
Old 03-18-2014, 09:45 AM   #8
AHH, SPANS!!!
Rewards Points: 1,166
as Joe mentions the replacement windows will use the existing window stops for inner and outer placement as long as the jamb is not rotten.
hand drive is offline   Reply With Quote
Tags
rot , window , wood
Where should wood floor stop and carpets begin. rickjames8 Flooring 5 05-08-2013 10:02 AM
OSB Stronger than Plywood? Weathermaker01 Flooring 15 12-22-2012 10:06 AM
Rotten wood replacement in a window frame - help! vanny Carpentry 3 09-02-2012 11:21 AM
How would you repair/replace this meeting rail? (57 yr old wood windows) cbrc5eric Windows and Doors 4 03-24-2012 11:55 AM
Windows XP Mode in Windows 7! poppameth PC Repairs & Upgrades 5 04-28-2009 01:18 PM
