Rotted Door Sill - Carpentry - DIY Chatroom Home Improvement Forum
Old 04-30-2011, 07:31 AM   #1
Rotted door sill
I recently noticed a rotted door sill under a slider. The door is on a room with no basement - its on a concrete slab. I can remove the old sill pretty easy but how do I attach a new sill to the concrete? are there any step by step instructions for this or a home improvement video?
jmm1678 is offline   Reply With Quote
Old 04-30-2011, 08:03 AM   #2
DIY staff
Rewards Points: 7,174
Are you removing the door to do this?
PL Premium adhesive would be my choice. a few Tapco screws would also help.
If possible.I suggest using a PVC board or composite deck board instead of wood.
A surface planer would be handy for making the board the thickness required.---Mike---
Old 04-30-2011, 08:11 AM   #3
A door a day is all I ask
TheDoorGuy's Avatar
It would probably help if you could post a picture of the situation.
Is the sill piece a 2x4 or 2x6 board?
If so, perhaps after you remove existing and clean up the area
you could slip in a new piece of treated lumber of similar size or better
yet slightly thinner.
You would want to use a lot of polyurethane caulk/adhesive.
Goop it on to the slab and the top of the new board and slide
it under the bottom track of the slider. Step on slider track to
make good contact.
You could probably secure all the way through the board into the
concrete by drilling with hammer drill (rent one if necessary) with 3/16?
bit and securing with those flat head blue concrete screws.... Just be
sure that they won't be in an an area that will interfere with rollers.
Just some guessing ideas at this point. A picture would help.
Good luck!
RC/DG
Richard The Door Guy
www.thedoorguy.com
TheDoorGuy is offline   Reply With Quote
Rotten Rotted Header! jlatulippe Building & Construction 1 10-06-2010 08:28 AM
How to repair rotted joists and studs? Snav Building & Construction 5 02-24-2010 10:35 PM
Rotted Sill Plate and Joists jhawk4ever Building & Construction 2 08-30-2009 08:03 PM
Repairing rotted studs against exterior wall sleepyscout Carpentry 11 07-01-2009 01:31 PM
Help: Rotted wall joists, wall frame plates, subfloor smallblockchevy Remodeling 8 07-22-2008 06:14 AM
