Rotted Column Replacement - Carpentry - DIY Chatroom Home Improvement Forum
Old 10-23-2013, 05:30 PM   #1
dmclean701's Avatar
Rewards Points: 152
Rotted column replacement
I need to replace a rotted 4 x 4 wood column supporting a pergola. I am planning on using temporary supports to hold the Pergola up. I am then going to cut off the rotted post above the damaged part. I will make a lapp joint to attach a new 4 x 4 piece. How long should the lap piece be, and would screws be appropriate to secure or should I use bolts? The Pergola has three 4 x 4 posts on the outside and the inside is attached to the house with a ledger board.
Sent from my iPad using DIY Forum
dmclean701 is offline   Reply With Quote
Old 10-23-2013, 06:53 PM   #2
Rewards Points: 13,260
#1 Replace the whole thing not just the bottom.
#2 I'd bet the reason it rotted was one of two things. Direct contact with the deck or patio, or it was set in concrete.
It needs to be sitting on a Simpson Strong Tie post base.
Windows on Wash (10-23-2013)
Old 10-23-2013, 07:45 PM   #3
dmclean701's Avatar
Rewards Points: 152
OK, I will replace all of it. It will require more disassembly but it can be done. I will get a post base. The cause is worse than you guessed. Someone thought it would be nice to place a built in planter around the bottom of the post, so it has been sitting in 18 inches of soil ever since it was constructed. Thanks for your reply.
Porch column base rotted RickO General DIY Discussions 17 10-25-2011 09:43 PM
Replacing a rotted 6x6 column in basement DJKevin Building & Construction 10 07-14-2011 08:06 PM
carport column replacement hometime General DIY Discussions 1 01-24-2011 12:37 PM
Replacement of 3 rotted railroad ties in wall system nailermen Landscaping & Lawn Care 2 09-28-2010 08:51 AM
Rotted sill plate replacement help handyd123 Building & Construction 2 08-25-2008 07:02 PM
