I need to replace a rotted 4 x 4 wood column supporting a pergola. I am planning on using temporary supports to hold the Pergola up. I am then going to cut off the rotted post above the damaged part. I will make a lapp joint to attach a new 4 x 4 piece. How long should the lap piece be, and would screws be appropriate to secure or should I use bolts? The Pergola has three 4 x 4 posts on the outside and the inside is attached to the house with a ledger board.
#1 Replace the whole thing not just the bottom.
#2 I'd bet the reason it rotted was one of two things. Direct contact with the deck or patio, or it was set in concrete.
It needs to be sitting on a Simpson Strong Tie post base.
OK, I will replace all of it. It will require more disassembly but it can be done. I will get a post base. The cause is worse than you guessed. Someone thought it would be nice to place a built in planter around the bottom of the post, so it has been sitting in 18 inches of soil ever since it was constructed. Thanks for your reply.
Sent from my iPad using DIY Forum
Related Threads
DIY Home Improvement Forum
3.1M posts
319.6K members
Since 2003
