RotoZip For Back Cutting Moldings? - Carpentry - DIY Chatroom Home Improvement Forum
Old 05-03-2012, 11:54 PM   #1
Rewards Points: 1,484
RotoZip for back cutting moldings?
Anyone else do this?
I've found it's easier to use my RotoZip than it is to use the old coping saw, and it's definitely a lot faster....
ktkelly is offline   Reply With Quote
Old 05-04-2012, 10:13 AM   #2
Too Short? Cut it Again!
I guess I could see using a rotozip but just never thought of it is a finish carpentry tool. Of new tools I used my oscillating Fein for such things more than anything else.
Old 05-04-2012, 10:53 AM   #3
Rewards Points: 14,300
When cutting base After the first back cut I flip it over and cut all but the ogee, and finish with a coping saw, if it's off I use a Dremal tool with a sanding drum.
Works for me.
kj6887 (05-05-2012)
Old 05-04-2012, 12:06 PM   #4
Retired Cabinetmaker
woody4249's Avatar
Rewards Points: 156
I use a good pair of compasses, a hand held coping saw and a piece of 100 grit sandpaper glued to a piece of dowel.............guess I'm "Old School"
Woody4249
woody4249 is offline   Reply With Quote
Old 05-04-2012, 06:09 PM   #5
double post
mrgins is offline   Reply With Quote
Old 05-04-2012, 06:11 PM   #6
I've used a knife, coping saw, rasp, and rotozip. If it's hardwood mouldings, then a rotozip is a good idea, but for soft wood, it's a bit aggressive and is just another cord to trip over
Old 05-04-2012, 07:39 PM   #7
journeyman carpenter
woodworkbykirk's Avatar
Rewards Points: 1,328
so your talking about coping moldings, not back cutting
when i cope joints i use a jig saw and cut from the back using the fine bosch blades which are borderline designed for coping.. much faster than a coping saw, more precise than using a table saw and no cleaning up the cut with a knife.. and less messy than using a angle grinder equipped with a flap sander wheel. ive also used the "copemaster" system which requires making a negative blank of the profile using resin, when the blank is ready it gets clamped into a jig which you simply use a trim router with a 3/16" flush cutting bit
woodworkbykirk is offline   Reply With Quote
Old 05-04-2012, 07:49 PM   #8
Don't know about the OP, but I'm talking about back cutting.
I'll have to try those bosch blades
Old 05-04-2012, 10:39 PM   #9
firehawkmph's Avatar
Rewards Points: 1,922
When coping I do like Kirk mentioned above. I use porter cable scrolling blades in my older p/c jigsaw,model# 7349. Any cleaning up I use a rattail file. After the first cope of the day, they go pretty quick, maybe a minute or less on a 4-6" base with a lamb's tongue on top for example. One thing that makes a difference for me is the p/c jigsaw has adjustable guide blocks on the bottom with a very small opening in the base plate. So it offers good support on the narrow width of the cope area, and the blade doesn't wander.
Mike Hawkins
firehawkmph is offline   Reply With Quote
RotoZip vs. Dremel 400 amakarevic Tools 6 03-05-2011 04:37 AM
Rotozip: How to Use for Electrical Boxes ralphfravel Building & Construction 11 07-24-2010 08:35 AM
Adhesive for transition moldings preciouschristy Flooring 4 08-21-2009 12:44 AM
Cutting in to baseboards? windowguy Painting 9 02-08-2009 09:20 AM
ceiling moldings feb Carpentry 4 08-29-2006 08:12 PM
