Rosette Location - Carpentry - DIY Chatroom Home Improvement Forum
Old 11-18-2008, 12:54 PM   #1
jelly's Avatar
Rewards Points: 330
rosette location
Where should I put my rosette?
jelly is online now   Reply With Quote
Old 11-18-2008, 12:54 PM   #2
Lic. Builder/GC/Remodeler
AtlanticWBConst.'s Avatar
Diagram # 3
- Build Well -
Old 11-18-2008, 12:58 PM   #3
jelly's Avatar
Rewards Points: 330
So if my jam reveal is 5/16", my rosette will over hang 5/16" on inside of the trim and about 3/4" on the outside perimeter? (my rosette is precut at 3") I would probably need to make my own rosettes?
Old 11-18-2008, 01:02 PM   #4
Your rosettes should be matched to the casing that you are using, so that the overhangs and reveals balance out.
Example:
- Build Well -
Old 11-18-2008, 01:29 PM   #5
Custom Cabinet Maker
Atlantic is right, as usual . As you have stated is also correct, if your rosette is not balanced to the trim than YES inside edge flush to jamb and outside is what it is.
skymaster is offline   Reply With Quote
Number, Size, and Location of Celing Vents GeauxCajuns82 HVAC 7 11-13-2008 11:40 AM
L/R Drain bath/shower over center drain location in floor? tigerbalm2424 Plumbing 2 12-04-2007 02:26 PM
How do you locate proper location for step handrails?? justdon General DIY Discussions 1 09-09-2007 08:10 AM
Help! What is Proper Way to Install Manufactured Stone? EricW Building & Construction 3 01-07-2007 04:56 PM
