Roman Ogee - Carpentry - DIY Chatroom Home Improvement Forum
Old 03-27-2011, 01:17 PM   #1
uva uvam vivendo variafit
WirelessG's Avatar
Rewards Points: 698
Roman Ogee
What are the rules behind designing a Roman ogee? It seems to me that there are some general rules that layout the proportions.
WirelessG is offline   Reply With Quote
Old 03-27-2011, 01:22 PM   #2
the Musigician
DangerMouse's Avatar
You want to design a router bit?
DM
Old 03-27-2011, 02:42 PM   #3
Rewards Points: 5,336
I always make sure there are enough togas available.
Ron
Old 03-27-2011, 04:36 PM   #4
recently retired
Rewards Points: 280
I'm guessing you are trying to determine the size of the ogee relative to other aspects of a form? In traditional architectural design there are rules about the size of things based on proportions of column height, diameter, etc. Here is a link which may help http://georgewalkerdesign.wordpress.com/. He also has a dvd out which covers things in detail.
Keith Mathewson is offline   Reply With Quote
Old 03-27-2011, 04:55 PM   #5
WirelessG's Avatar
Rewards Points: 698
No, I'm trying to find out how you draw an ogee. I knew how to do it at one point, but I can't remeber anymore. I'm making two entry gate that will have an ogee for a top profile. I can wing it if needed, but I would rather draw it correctly from the start.
Old 03-27-2011, 06:34 PM   #6
recently retired
Rewards Points: 280
There are a couple of ways to do it but for what you want it might be easiest to draw a straight line from the high point at the middle of the gate to the edge. Find the middle of the line and mark it. Lightly freehand the curve you want. Now take a compass and set to about the radius needed place one point on one high point and swing and arc. Next put one point on the middle of the line and swing an arc. Where they intersect place a point and swing and arc through the line, adjust until desired arc is reached.
Old 03-27-2011, 09:26 PM   #7
WirelessG's Avatar
Rewards Points: 698
Here's what I came up with.
Old 03-27-2011, 11:45 PM   #8
recently retired
Rewards Points: 280
It looks good, do you know how to determine your radius points to swing your arcs?
Old 03-27-2011, 11:51 PM   #9
WirelessG's Avatar
Rewards Points: 698
Thanks. What I did was pick a spot where I wanted to put a point of inflection, drew an arc, and then mirrored it twice, and those two arcs combined gave me on side of the ogee. I let CAD tell me what the radius is.
Old 03-27-2011, 11:56 PM   #10
recently retired
Rewards Points: 280
I understand, will it tell you where to set the radius point to run a router?
Old 03-28-2011, 12:01 AM   #11
WirelessG's Avatar
Rewards Points: 698
It should, but I'd have to fool with it to figure out what the command is. How would you go about getting the center?
After Thought: I guess by striking an arc back from two points on the curve and using the appropriate radius.
So is it this easy? (Roman Shades) DownRiverGuy Interior Decorating 1 01-26-2011 10:35 AM
Roman Facut - Replace Delta w/American Standard mormegil Plumbing 1 11-29-2010 08:37 PM
greetings from Roman Roman Introductions 0 11-10-2010 12:31 AM
Replacing Moen Roman Tub Faucet - How to get out old hardware? mav1c Plumbing 1 08-09-2010 10:57 AM
roman shower valve rebec Plumbing 0 08-06-2010 04:38 AM
