Rlh5harts - Carpentry - DIY Chatroom Home Improvement Forum
Old 05-27-2007, 03:02 PM   #1
rlh5harts
i have a 4x8 slab of cement, i would like to use this as a floor for a small shed, since the cement has been cured for a couple months i need to know hw to attach the 2x4's for the wall frames to the cement. any suggeestion would be appreciated.
thanks
rlh5harts is offline   Reply With Quote
Old 05-27-2007, 03:22 PM   #2
there are a variety of concrete anchors/fasteners for this purpose. Everything from powder-driven nails, like ramset, to expanding metal sleeves, like RedHead (is that the name? Somehow it's not sounding right), or Tapcon threaded concrete screws that just screw into a hole in the concrete. You can browse all these at your local lumberyard or building center.
NateHanson is offline   Reply With Quote
Old 05-27-2007, 03:32 PM   #3
concretemasonry's Avatar
Rewards Points: 2,578
2x4s
Make sure you use pressure treated 2x4s.
also when nailing into the pressure treated lumber, use the proper type of nails to eliminate the problem of the PT wood eating up the nails.
concretemasonry is online now   Reply With Quote
Old 05-27-2007, 03:41 PM   #4
Lic. Builder/GC/Remodeler
AtlanticWBConst.'s Avatar
In other words use galvanized nails or fasteners....(NOT brights)
- Build Well -
