Rip Cut Molding? - Carpentry - DIY Chatroom Home Improvement Forum
Old 09-06-2010, 08:40 AM   #1
Rewards Points: 492
rip cut molding?
the last three corners I have to work on will all be less than 3". the molding I've been working w/ is 3".
due to the irregularities of the post, I can think of two options.
1. get the molding ripped (will depot rip molding?) to the widest width i need and use a belt sander to get a good fit.
2. cut the molding with a jigsaw and sand to fit.
The gap gradually widens to about 3/4" as you go down.
On another corner I had a similar gap that was initially wider. I actually fit another 2 X 4 in it. I then caulked the remaining gap, which still widened to about 1/2" . I put some rigid foam insulation in the gap and caulked. It was messy to do, but it now looks clean. I still want to do something with the existing space.
Other corner
joetab24 is offline   Reply With Quote
Old 09-06-2010, 09:37 PM   #2
Rewards Points: 5,336
You need to scribe flat stock to the wall. You would measure the largest gap and use a board that was as large.
Ron
Paint Crown Molding Before or After Installation? gmhut Painting 28 12-30-2016 06:20 PM
positioning molding joetab24 General DIY Discussions 0 08-11-2010 07:38 AM
Solidly Securing Picture Rail Molding? Lovegasoline Building & Construction 13 11-25-2009 03:13 PM
Crown molding on with catherderal celing for LED lights My_attempt Carpentry 20 07-22-2009 11:52 AM
Help with adding a strip of molding over baseboard. Bobrobert Remodeling 15 01-15-2008 11:12 PM
