Rim Joist Alignment Question - Carpentry - DIY Chatroom Home Improvement Forum
Old 07-10-2007, 02:44 PM   #1
Rim Joist alignment question
Hi everybody. I have a brother in law who is building a geodesic dome over a basement that was built using ICF's. I noticed that he was using 2 x 10 sill plates that came out flush with the outer edge of the icf's. This means that the inside edge of the 2 x 10 sill is flush with the inside face of his basement wall, but that the outer edge of the sill was extending over the actual concrete wall by about 1 1/2". My concern was that if he were going to set his rim joist flush with that outer edge that it would actually be setting over the ICF. Has anybody ever seen this done? There are sufficienct anchors on the sill that are embedded into the wall.
jim
jcbays is offline   Reply With Quote
Old 07-10-2007, 07:28 PM   #2
Who determined the thickness of the icf's?
Who determined the thickness of the sill ?
redline is offline   Reply With Quote
Old 07-11-2007, 06:36 AM   #3
He chose the thickness of the forms that gave an acceptable r value. The sill width is a 2 x 10 because the wall is 9" thick, the forms 2.5", and because he wants to put on some type of decorative exterior. What he is doing I have found in the form manufacturer's manual as an optional sill plate configuration. Basically it is a cantilevered sill.
Cutting/drilling hole in joist - How big? curls00 Carpentry 3 07-20-2007 10:56 PM
Garage Ceiling Joist Question ejarlos Building & Construction 3 07-11-2007 07:27 AM
Question about rotting rim joist dem372 Building & Construction 2 06-28-2006 08:15 AM
Any way to allow a 3.5" bore through a 2x10 floor joist? peeks Building & Construction 1 07-06-2005 03:02 PM
