Rigid Insulation In Basement - Carpentry - DIY Chatroom Home Improvement Forum
Old 01-21-2011, 10:19 AM   #1
rigid insulation in basement
Hi. I rent a +50 year old home with cinder block exposed foundation in my basement. I want to insulate my laundry room 'cause it's really cold down there right now, and the bathroom above is cold as well. I don't have much space, everything is right up against the walls with only a narrow space to be able to open the dryer door. What's the minimum thickness of rigid foam I could use, and not make it a complete waste of $ investment? Also can I leave the rigid foam just exposed after? I'm not interested in fully finishing the laundry room, so don't want to put the $ into a stud wall, and lose the precious inches.
Thanks!
belindapotter is offline   Reply With Quote
Old 01-21-2011, 10:45 AM   #2
ccarlisle's Avatar
I'd be looking at extruded polystyrene - the blue stuff - that comes in 2'x8' sheets. Not the white stuff, that's not as efficient an insulator for the $$. Thickness will depend on what you fit in, but in Toronto, I'd be looking at 1.5" thick...those are about $18 each, I think. Look at gluing them to the walls with appropriate glue and tape the joints; look into doing the same for the space above your joists.
The codes say they should be covered with drywall, but what you do is of course your own responsibility.
“The average American woman is about 25 pounds heavier than she was in 1960...Recognizing obesity as a disease will help change the way the medical community tackles this complex issue that affects approximately 1 in 3 Americans,”
ccarlisle is offline   Reply With Quote
The Following User Says Thank You to ccarlisle For This Useful Post:
belindapotter (01-21-2011)
Old 01-22-2011, 12:36 AM   #3
Registered User
Rewards Points: 5,180
The foam board should be taped and sealed so no interior air can get to the concrete block to condense there, Fig. 17; http://www.rlmartin.com/buildingscie.../enclosure.htm
Laundry rooms are moisture producing rooms.
Don’t forget the rim joists, as CC said; http://www.rd.com/57548/article57548.html
I would be concerned leaving foam board exposed next to the washer/dryer, possible ignition sources. Especially a gas dryer, if so equipped. Check with your landlord on this and your Renter Insurance Policy, to be safe. Even if you used the blue foam below , covered with drywall and the upper wall covered with foil faced polyiso board (some B.D. let it be exposed, check with yours), fig. #12; http://www.buildingscience.com/docum...lation-systems
Gary
Old 01-22-2011, 01:01 AM   #4
Rewards Points: 508
You can buy foam that's recessed for furring strips. I'm putting in two layers of 2" foam, but the first 2" layer really made a difference.
If you get really ambitious and you want to put down tile in this rental, look into Wedi board to provide a thermal break.
Check out this video from Owens Corning:
benjamincall is offline   Reply With Quote
Tags
basement , insulation
How To Install Rigid Foam Insulation on Concrete earthad1 Building & Construction 9 10-26-2010 10:49 AM
basement insulation - condensation behind the batt insulation natalie Building & Construction 3 01-31-2010 11:19 AM
Basement Insulation and humidity control mcwolfe6 General DIY Discussions 11 01-28-2010 07:02 PM
Basement Insulation raulakh Building & Construction 2 10-13-2009 01:36 AM
basement insulation and vapour barrier coolnes Remodeling 11 02-01-2009 09:56 AM
