-   -   rhignz (http://www.diychatroom.com/f14/rhignz-40200/)
rhignz 03-12-2009 03:16 PM
rhignz
I want to remove an existing railing around an opening 48 inches by 110 inches (leading to the basement) and replace it with a wall. If the wall will only be attached at one end and the other end (the 110" meaurement) is free standing, what do I need to do to make sure the end of that wall is not wobbly?
DangerMouse 03-12-2009 03:59 PM
hi and welcome to the forum.
mount it to the floor and ceiling? should be fine.....
DM
Bob Mariani 03-12-2009 05:39 PM
search this forum this has already been discussed and some good options are available. I am assuming you are using a knee wall (short wall)
Ron6519 03-13-2009 09:42 PM
Since this is going to be on or next to the staircase, I would bolt it through the tread, stringer or riser depending on your configuration. Add a 2x piece of blocking to add to the thickness of the stair part you use.
To increase the lateral rigidity I would glue and screw a plywood skin on both sides of the wall framing. You could use 1/4" ply and cover it with 1/4" sheetrock to minimize the thickness.
Ron
