Resheathing Round Power Meter, What Should I Do? - Carpentry - DIY Chatroom Home Improvement Forum
Old 10-04-2010, 07:49 AM   #1
Question
Resheathing round power meter, what should I do?
I'm resheathing and siding my house and I'm not sure what I should do around where the electrical comes in, it looks like the original sheathing was put under the power meter which will make it hard to tear off the old stuff. Or should I have an electrician (or power company) come and pull it off?
tsg234 is offline   Reply With Quote
Old 10-04-2010, 07:58 AM   #2
I had a piece of painted plywood installed behind my meter
Its flush to the side of the meter
I then side up to the meter
You could cut the existing siding flush with the meter
Then side up to the meter
Or you will need an electrician & probably need power shut off
Here that requires a permit & inspection
Tags
power lines , power meter , power supply , sheathing , siding
Tiny elbows on meter? pcampbell HVAC 24 10-06-2009 09:54 AM
Water meter aggravations Ultrarunner2017 Plumbing 8 03-21-2009 06:53 AM
Turning main power supply off from the meter amakarevic Electrical 2 05-22-2007 10:33 PM
Problem W/ Power after Switching Outlets... G19-Fanatic Electrical 17 08-28-2006 01:55 PM
Partial power on same fuse! joyjam Electrical 5 07-10-2005 10:23 PM
