Replacing Stair Treads - Carpentry - DIY Chatroom Home Improvement Forum
Old 03-29-2011, 10:34 PM   #1
replacing stair treads
Working on a project and any help would be great! Im redoing a carpeted stair case! I choose the route of replacing the treads and risers with pine!Ive measured and cut each piece! And have stained and polyed them and they turned out great! So my first question is the top step is an inch and a half higher due to a subfloor and new wood flooring so whats the best way to shim up the risers to graduate the difference? And whats the best way to install the treads nails and liquid nails? or screws? And do I need to drill pilot holes! And how to match the putty to fill the holes? Again any help would be great!
graeserhp is offline   Reply With Quote
Old 03-29-2011, 10:47 PM   #2
Residential Designer
AndyGump's Avatar
Rewards Points: 666
Send a message via Skype™ to AndyGump
What made you decide on pine as the material for the treads?
Andy.
AndyGump is offline   Reply With Quote
Old 03-29-2011, 11:06 PM   #3
I went with something to stain to match the floor! Is pine bad?
Old 03-30-2011, 12:22 AM   #4
AndyGump's Avatar
Rewards Points: 666
It seems to me that pine is much too soft a wood to be used as a floor or tread surface.
There are particularly hard pines but kind of rare and I think quite expensive.
Andy.
Old 03-30-2011, 05:36 AM   #5
the Musigician
DangerMouse's Avatar
funny... the VERY FIRST THING I see when I open the "How To Guides" section is...
Do not post questions in this sub-forum!!!!
*sigh*
Question moved to appropriate forum section.
DM
The Following User Says Thank You to DangerMouse For This Useful Post:
BigJim (03-30-2011)
Old 03-30-2011, 07:28 AM   #6
Rewards Points: 5,336
Originally Posted by scophone View Post
You're a talent !!!
What's with all the inane comments?
Every post sounds like a stroke victims lament.
Ron
Old 03-30-2011, 08:38 AM   #7
Experienced
Jackofall1's Avatar
I am afraid you may have caused yourself some extra work due to the order in which you performed the work.
I would say that screwing the stair treads would be the best way, but the counter sink holes will cause you some trouble as the treads are already finished, buy some doweling and make the countersink holes deep enough to dowel them, or just use doweling and glue. You will have to stain and finish these, and it will be difficult to match what you have already done.
I think the biggest job you have created is the adjustments you have caused yourself by increasing the subfloor height. I am not real sure how you will change this, do the stair treads sit on the rails or has there been a relief cut into the side of the rail?
Hopefully for you they sit on top, otherwise you may have to rebuild the whole thing.
Post some pictures of the subfloor and stair rails.
Mark
Edit - Pine is a soft wood and when used for stair treads is usually under carpet, as it marks far too easily.
Old 03-30-2011, 10:09 AM   #8
Ole Wood Worker
BigJim's Avatar
Rewards Points: 288
Originally Posted by Jackofall1 View Post
Mark
Except antique heart pine.
New members: Please consider adding your location to your profile.
If you do what you've always done, you'll get what you've always got.
http://www.woodworkingtalk.com/forum.php
Jim
BigJim is online now   Reply With Quote
The Following User Says Thank You to BigJim For This Useful Post:
DangerMouse (03-30-2011)
Old 03-30-2011, 10:13 AM   #9
Experienced
Jackofall1's Avatar
I guess you would have to be of the same era of that pine to know about it........, good call
Mark
Old 03-30-2011, 11:54 AM   #10
Thanks for the input! The added floor hieght was already done before i moved in!Just not sure how to correct the problem!
Old 03-30-2011, 11:56 AM   #11
And yes the treads do sit on top of the rails
Old 03-30-2011, 12:14 PM   #12
Experienced
Jackofall1's Avatar
What is the step with the greatest differential? and what is the measurement.
I believe code recommends that a deviation from stair riser to riser can't exceed 1/4" and a riser can not exceed 8".
Mark
Old 03-30-2011, 03:50 PM   #13
the steps are 7 and 3/4 in height then the top step is 9 and 1/8 there are 6 steps I was wondering if I graduate each step a 1/4 to make the top step almost the same?
Old 03-30-2011, 04:04 PM   #14
Experienced
Jackofall1's Avatar
Thats about all you can do short of rebuilding the entire strair case.
Fire up the ole table saw ans start cutting!
Mark
Old 03-31-2011, 01:08 AM   #15
recently retired
Rewards Points: 280
It would take longer to do and be considerably worse than just ripping out a 7 riser stair and doing it right. This kind of thing is how we end up with building inspectors.
Keith Mathewson is offline   Reply With Quote
Refacing stair treads Stair newbee Flooring 2 08-10-2010 10:35 PM
How do I install trim around stair treads? JayBird Carpentry 22 08-07-2010 04:16 PM
New stair treads and flooring rickkeeter Flooring 2 02-24-2010 10:16 PM
Ugly old painted stair treads, with seriously raised grain. Salvageable? CharmCityFixer Flooring 9 01-29-2010 06:40 PM
