Replacing Stair Tread On Closed Stringer Stairs... - Carpentry - DIY Chatroom Home Improvement Forum
Old 06-20-2013, 08:02 AM   #1
They're all fixer-uppers
J187's Avatar
Rewards Points: 516
Replacing stair tread on closed stringer stairs...
I have a split level home and I need to replace a couple of stair treads. The stairway is a closed stringer stair - so I have no access to either side of the stringers as everything is enclosed by walls.
This is not my stairway, but it's similar
I'm really not sure how to approach replacing the treads - I imagine I can cut the old one out in pieces with a reciprocating or circular saw, but how would I get new stair treads in there?
J187 is offline   Reply With Quote
The Following User Says Thank You to J187 For This Useful Post:
sophiah (01-16-2017)
Old 06-20-2013, 08:05 AM   #2
Rewards Points: 6,652
You have to get underneath it, to replace them. What is going on with the ones you need to replace? As for your stairs, really need a picture of yours, not some photo off the web. A little misleading.
Old 06-20-2013, 08:17 AM   #3
Rewards Points: 14,306
Look close at the treads, can you see the finish nails holding them down?
100% sure the treads are not dadoed into the side skirts?
If there just a line to line fit tread and you can find the nails you can drive the nail in with a small nail set and tap the tread up to get it out.
I'd keep the tread in one piece so I could use it as a template for the new one.
There's going to be some paint touch up on the skirts more likely.
Where the tread touches the riser I sometime cut it at a very slight angle so only a small area makes contact with the riser so you can get a tighter fit.
Duckweather (06-20-2013)
Old 06-20-2013, 10:12 AM   #4
Haverhill Trade 1965
You can also get a set of pin punches from tool / automotive stores. They come in many sizes and they are not tapered like a nailset so they don't make holes larger than the nail. Good for punching nails through if you have to reposition part of a door frame.
Duckweather is offline   Reply With Quote
Old 06-21-2013, 09:55 AM   #5
J187's Avatar
Rewards Points: 516
Thanks. I'll try to get a pic of the stairs, but I was at work when I thought of it and stock pics work plenty often for conveying enough info - if an actual pic is then necessary, it can be obtained.
I do have access from under the stairs via a crawl space, but one of treads I need to replace is the bottom one. There are two treads that are splitting, and I'm getting ready to refinish all the floors and paint the stringers/skirts/risers/ etc anyway.
I will look tongiht to see if the nails are visible.
Old 06-21-2013, 10:07 AM   #6
Ole Wood Worker
BigJim's Avatar
Rewards Points: 778
Do your stairs look like this from the back side?
New members: Please consider adding your location to your profile.
If you do what you've always done, you'll get what you've always got.
http://www.woodworkingtalk.com/forum.php
Jim
BigJim is online now   Reply With Quote
Old 06-25-2013, 01:31 PM   #7
J187's Avatar
Rewards Points: 516
Old 06-25-2013, 01:58 PM   #8
Still need a photo from underneath.
Old 06-26-2013, 10:33 AM   #9
Stair Tread installation
As long as the treads are fitted between the skirts and not dadoed into them, both the removal and replacement is fairly simple and access to the underside of the stair is unnecessary. Here is a blog post http://www.woodstairs.com/tradepage/...queaky-stairs/ with some information. It deals specifically with preventing squeaky stairs but in so doing discusses some of the installation methods. There are other similar articles there as well.
titanjt is offline   Reply With Quote
Old 06-27-2013, 06:10 PM   #10
That looks like a split entry house, and I doubt if the stairs in a house of that era would have housed stringers
Old 01-16-2017, 06:10 PM   #11
Rewards Points: 8
Re: Replacing stair tread on closed stringer stairs...
My house has similar stairs which need to be replaced
sophiah is offline   Reply With Quote
Old 01-16-2017, 06:24 PM   #12
jlhaslip's Avatar
Rewards Points: 2,872
This Thread is 4 years old.
If you need some help, please start a new thread.
Short of cutting off a body part, the worst that can happen in woodworking is manufacturing really nice looking kindling. --- Quoted from lenaitch
jlhaslip is offline   Reply With Quote
Gap in my diy made stair treads along stringer cybernation Carpentry 10 03-19-2013 09:41 PM
Plywood Stair Stringer ralphfravel Carpentry 4 11-01-2009 09:39 PM
replacing slab, how to replace under stairs johnny331 Building & Construction 1 01-02-2009 07:57 PM
Stair Tread And Riser Installation Speckert General DIY Discussions 3 11-19-2008 02:33 AM
