Replacing Some Of Deck - Carpentry - Page 2 - DIY Chatroom Home Improvement Forum
Old 08-03-2013, 07:05 AM   #16
kwikfishron's Avatar
Rewards Points: 760
Originally Posted by sdsester View Post
Unless I am missing something, I think the thickness of the deck boards is the least of your problems OP.
It almost looks like there's a strap hanging off that corner as if there might have been a post there, or one can only hope.
kwikfishron is online now   Reply With Quote
Old 08-03-2013, 07:28 AM   #17
Rewards Points: 13,960
No one here knows how this house was framed, if the joist run all the way into the house under the floors at least 10', (more would be better) what's wrong with the cantilever?
T & G 2-1/4" X 3/4" decking boards have been used on nearly every 100 year old house's front porch I've ever worked on.
One thing I do see that's missing is the blocking between the joist to support the deck boards.
A real lumber yard, not a box store should have pressure treated, Fir or even composite 2-1/4 X 3/4 deck boards.
I would use 6" long hex head ceramic coated Deck Loc screws in that new rim joist, any box store will have them in the fastener area next to the decking screws.
That new rim joist needs to be Pressure treated.
Old 08-03-2013, 07:40 AM   #18
Too Short? Cut it Again!
Hope and faith are always good things. But hope there was once a post there or that we all we hound the OP until there is one?
I admit I have become somewhat pleasantly plump as I have aged. Or width may not exactly match height. I guess I could disguise it all well cross dressing with the next size larger moo moo, painted nails, and flip flops. Or a maternity dress. But...
You are not getting me and my baby near the far corner of that deck until somebody proves something is supporting it. Encouraging the OP to buy new decking is not helpful in this instance? It really does look like the metal work is holding that deck.
I say again. Very scary. Given the rot I am seeing, I would actually think about just demolishing it and rebuilding it properly. Worrying about where to find 3/4" decking for that structure is madness. And dangerous.
Old 08-03-2013, 07:50 AM   #19
Rewards Points: 760
Whats supporting the roof? It looks like the last 2' is an add on with the original fascia running down the middle of it.
Old 08-03-2013, 07:54 AM   #20
Totally agree Joe. If the deck support is sistered to joists way inside the house, to counterbalance the weight, I guess I get the structure and can somewhat believe you can hang that much weight in dead air.
But exposed timber weighing what this deck does hanging outside? I could see it working with some steel.
If this thing is hanging off a rim joist, ledger, or whatever you want to call it though? In midair with no posts to support it? That iron work and the screws holding it in place to the roof soffit is the only possible support I can see.
Kwikfishron may have nailed it. It does look somebody removed at the least one corner post from this thing. It really needs it back.
Old 08-06-2013, 04:02 PM   #21
Every other joist runs into the house and I guess that's what is supporting the deck.
johnsorious is offline   Reply With Quote
Old 08-06-2013, 08:01 PM   #22
Registered User
Rewards Points: 526
Do you have the 16"oc blocking between the joists to support the decking boards, not pictured? Is the span more than 53" with 35# or less snow load, with every joist extended in to the building per code; second chart down; http://publicecodes.cyberregs.com/ic...002_par019.htm
Gary
Cedar deck help mickbiv Painting 11 08-08-2013 09:21 PM
22x14 DECK W/ROOF SLIGHT SWAY NEED HELP FROM EXPERTS clfdpops1 Building & Construction 38 06-09-2012 06:21 PM
Replacing existing load bearing deck posts Tubachin Building & Construction 2 09-07-2010 04:33 PM
Building a new deck......suggestions? thoughts? Rhizzlebop Building & Construction 38 06-24-2009 05:07 PM
replacing rotted sill plate and rim joist behind a deck ledger board tommyt Building & Construction 2 08-11-2008 07:38 PM
