-   -   Replacing a sliding glass door question (http://www.diychatroom.com/f14/replacing-sliding-glass-door-question-100749/)
cdm 04-06-2011 04:30 PM
Hi Everyone,
I am in the process of re-doing my kitchen and one of the projects that I am doing is replacing the exisiting sliding glass door. The old door is leaking and there is some damage to the subfloor. My question is on the exterior of the home the vinyl siding goes right up until the J-channel and the J-channel is against the old sliding glass window. The new replacment window that I bought ( A Pella 6' wide from Lowes). Has a large nailing flange that is around it. My question is can I cut this nailing flange down to install this new door or do I need to pull my siding (not what I want to do). Thanks for the help
CDM
Ron6519 04-06-2011 05:38 PM
Originally Posted by cdm (Post 624764)
Hi Everyone,
CDM
You need to remove the siding for 2 reasons. To get the door in place and secured properly and to install the membrane flashing over the flanges.
Ron
cdm 04-07-2011 06:44 AM
Ron
Thanks for the feedback. I got a quote from a Lowe's installer ($600 by the way) and he said they just cut the flange off and seal it up with caulk. So I assume you disagree with his technique. I just didn't want to spend $600 for someone to do half a days work (according to him). I'll post pictures tonight.
Chris
tcleve4911 04-07-2011 06:47 AM
I wouldn't want to pay someone $600 to do it wrong!!!!!
Ron's correct.
You HAVE to remove and reinstall the siding.
Most of the time the siding has to be recut to fit properly.... especially the piece going over the top of the new door.
kwikfishron 04-07-2011 07:04 AM
199 Attachment(s)
Originally Posted by cdm (Post 625026)
Ron
Chris
This is a perfect example of why to “Never Use Box Store Contractors.”
"if you hear it from a guy in the apron store, be VERY suspicious the mtl/method will work,,, when it comes to building something together, their phone won't be answered :laughing: NOR will they help :furious: "
itsreallyconc
Ron6519 04-07-2011 07:26 AM
Ron
Chris
Spending 10 minutes doing research on the manufacturers website would have told you that advice was imbecilic.
The door comes with instructions. What do they say?
Ron
cdm 04-07-2011 08:00 AM
I have another contractor coming out today to give me another quote. The instructions don't say cut the flange off. I didn't think what he said was correct that is why I was asking on here. Hopefully this other guy won't suggest the same thing. Problem I am having is finding someone to come out and do such a small job.
Chris
rjniles 04-07-2011 08:44 AM
Chris
Installing a replacement slider is not such a small job and $600 to do it right is a fair price. It could be a lot more if there are other issues: the damage to the subfloor and any other rot issues should be repaired.
cdm 04-07-2011 09:12 AM
Well then do you think I would be able to remove the J chanel, bend the siding back install the new door then re-install the j chanel?
Ron6519 04-07-2011 09:36 AM
I don't think siding is that flexible, even in the Summer. In cooler weather it will crimp. In cold weather it will crack.
I had a similar issue with a sided house with 2 bad windows 6 feet apart. I had to remove almost 25% of the siding on the house to replace the windows and install them properly. It took twice as long to deal with the siding then it did the 2 windows.
Ron
cdm 04-07-2011 09:43 AM
Well this is probably a stupid question but do they make replacement sliding glass doors that do not have a nailing flange that still provide a good water tight seal, or would you recomment going with a door that has the flange?
Ron6519 04-07-2011 10:06 AM
You cannot get a watertight seal without removing the siding. I don't care how many idiot contractors come to your house and tell you differently.
Ron
cdm 04-07-2011 12:06 PM
Ron
Thanks for the help. I agree that removing the siding is def. the way to go.
Chris
COLDIRON 04-07-2011 05:58 PM
1 Attachment(s)
Yes, just did the replacement of a slider. Home depot has one that requires you to put together the frame it's made by Pella but the name is something else don't have it in front of me right now It will fit right into the opening. Now make sure you have a good power saw to cut the old one out and leave the old nailing flange in place. Get some foam and good silicon follow the instructions that come with the door. Most of the sealing surface is under the door anyway. Only use the foam sparingly if needed rely on the silicon and the door comes with long screws that go into the sides 8 each side and top.
You can cut the nail strip off and sand it flush.
kwikfishron 04-07-2011 06:11 PM
199 Attachment(s)
Cdm, this is exactly the type of installation you do not want to do.
It’s done all the time by box store and other contractors that just want to get that
slider/window on the hole as easy and fast as possible.
The only one that benefits from this type of installation is the installer.
