Hello,
I am trying to use the internet to cut my learning curve down.
About ten years ago I replaced the front of our double garage. At that time I used a jack and lifted one side and then the other of a beam. I put a beam to stretch across the rafter/joists and carry the load and put 4 x 4's under the beam (16') (I left 3' on each side not lifted as there were walls). I put in a new header for the double garage door and new sill plates. Now I need to do the opposite side.
The garage was built on a slab. I was thinking of adding a course of concrete block to put the sill plate on. I'm not sure it would buy me much more time than treated lumber would. This garage is about 35 years old and was built before treated lumber was common.
I came to this forum to ask this question: Would most people just replace the sill plate and call it a day? Or would you go to the effort of adding concrete block? That all being said: Would you use any felt paper under the sill plate to put a barrier between the wood and the concrete?
Thank you for your help.
Kathryn Cecelia "KaCe"
