Replacing Rotted Siding On Gable Roof - Carpentry - DIY Chatroom Home Improvement Forum
Old 07-14-2010, 11:49 AM   #1
replacing rotted siding on gable roof
I was wanting to replace the pine siding in front of my garage.
Its stood vertical and goes like above my garage door to the peak of my gable roof.
what is the best way to know how to cut my boards for the angles?
thanks1
psd7.3 is offline   Reply With Quote
Old 07-14-2010, 12:29 PM   #2
47_47's Avatar
Rewards Points: 44
You could use a bevel gauge to transfer the angle to your siding.
47_47 is offline   Reply With Quote
Old 07-14-2010, 12:59 PM   #3
kwikfishron's Avatar
Rewards Points: 194
Just save one of the old boards for a pattern.
kwikfishron is online now   Reply With Quote
Old 07-14-2010, 02:27 PM   #4
Registered User
Rewards Points: 5,236
Check the garage door head flashing for possible replacement at this time....
After cutting the rake top cut, hold the board up where it goes to mark the door head (bottom cut), much easier than measuring twice (wall/board). If you have continuous ridge vent and a gable vent, cover the gable vent and side over it. Leave a proper gap at the top if butting an overhang. The pine siding will move a lot compared to the plywood soffit overhang (especially in full sun), if applicable. Use backer rod (or caulk saver) http://www.lowes.com/lowes/lkn?actio...464&lpage=none to get a good hourglass shape with the caulking for maximum movement durability: pp. #30- http://books.google.com/books?id=fDs...age&q=&f=false
pp. #35: http://books.google.com/books?id=XHA...0break&f=false
The caulking must not bond to the back, hence backer rod: (more on bead width) http://www.coastalcontractor.net/article/117.html
Ok, now I’m rambling on…
Be safe, Gary
New siding before new roof? Dbn107 Building & Construction 4 04-07-2010 11:24 PM
gable roof tie in framing moonshadow Roofing/Siding 4 08-20-2009 09:03 PM
Changing gable over hip roof to gable end billybarty Building & Construction 2 03-11-2008 12:20 PM
Replacing flat roof producto Roofing/Siding 1 03-09-2008 04:58 PM
Cost of replacing a rafter in our roof??? bikerboy337 Roofing/Siding 3 04-24-2005 07:19 AM
