Replacing A Rotted Floor In A Bathroom - Carpentry - DIY Chatroom Home Improvement Forum
Old 03-13-2011, 01:01 AM   #1
replacing a rotted floor in a bathroom
my house was built in 1890,the main bathroom has a concrete floor, but due to the toilet leaking, the shower water hiting the floor, the wall connected to the floor is rotted, the wooden floor under the concrete that connects to the wall is rotted, how do I fix this
MRH45255 is offline   Reply With Quote
Old 03-13-2011, 07:19 AM   #2
DIY staff
Rewards Points: 7,174
This will require pictures------Post some--you will get suggestions---This is a common problem--
However the older houses used balloon framing very frequently---so we need pictures to offer any real assistance.------Mike------
Old 03-14-2011, 05:00 PM   #3
Master of none
As mike said, a lot more info is needed. Can you get under the floor easily? If yes, then sistering the old joists may work depending how bad they are. In any case you will have to replace some or all of the floor.
Also the wall repair will depend mostly on the wall construction and extent of the damage. If you have mould, then the problem could get bigger!
handy andy is offline   Reply With Quote
Rotted sole plate in bathroom firemanter Carpentry 3 05-30-2013 02:14 PM
Replacing shut off valves in bathroom Haugenbp Plumbing 11 05-30-2011 08:12 AM
replacing all above joists in bathroom reno... Bob the blunder Flooring 2 12-03-2008 08:40 AM
Replacing Bathroom Light Fixtures, going from one to two. diynewb Electrical 3 11-25-2008 10:16 AM
Advice on replacing bathroom fixtures t1000 Plumbing 3 07-11-2008 02:42 PM
