Replacing Outside Wall Stud-Termite Damaged-advice Needed. - Carpentry - DIY Chatroom Home Improvement Forum
Old 02-03-2008, 01:58 PM   #1
DIY Expert in Training!
Replacing outside wall stud-Termite damaged-advice needed.
I am replacing this stud because there was some termite damage. Cut the nails and removed easily. Behind it the outside wall has some damage. Possibly from removal, when the original owner did work on it, or from the termites. Regardless, I have some gaps that are allowing air in.
How do I fix so I can put the new stud in?
Thinking about using caulk to seal the small gaps then putting up 15# tar paper.
gone_fishing is offline   Reply With Quote
Old 02-03-2008, 02:04 PM   #2
Lic. Builder/GC/Remodeler
AtlanticWBConst.'s Avatar
Spray Foam:
http://greatstuff.dow.com/greatstuff/diy/index.htm
Once dry and fully cured, use a sharp utlility knife, cut away what you need to (in order to install the replacement stud).
Because there obviously will be less space there (due to the foam), consider cutting the stud width down a little, or installing a doubled up 2x3 (side by side) into that area.
- Build Well -
Old 02-03-2008, 02:05 PM   #3
Got that...put stud up then spray away?
Old 02-03-2008, 02:13 PM   #4
Yeah, that would be the easiest way. The cans have direction nozzels, so you could fill that area after installing the studs with no problems...
- Build Well -
Old 02-03-2008, 03:12 PM   #5
Thanks for the tip...I sprayed and will give it time to dry.
How to butt wood stud wall to steel stud wall? Yorkergizer Building & Construction 3 12-01-2007 01:28 AM
Help Repair Garage Wall - Advice RandomJustice Building & Construction 8 07-28-2007 11:02 PM
Atlantic-need your opinion on markd's comments about my vapor barrier? yummy mummy Building & Construction 11 03-07-2007 10:47 AM
Replacing damaged shower wall tiles kevind Flooring 4 11-20-2006 01:18 PM
Replacing damaged shower wall tiles kevind Remodeling 3 11-15-2006 11:36 PM
