Replacing Outdoor Steps - Carpentry - DIY Chatroom Home Improvement Forum
Old 03-30-2011, 10:07 AM   #1
replacing outdoor steps
Hello, now that the weather is warming up I need to address my outdoor steps which are falling apart. The previous owner hadn't graded the area properly so the part by the steps slopes back towards the house and the wooden steps are rotting as they are in direct contact with the ground.
My question is once I regrade the area to provide a proper slope I will only have 16 inches or so from the top of the concrete to the finished grade so I figure that a traditional step wouldn't work as I will only have one tread unless I make the rise very small.
My intial thoughts are to make a 2x3 platform and set it on some precast concrete piers with about a 7 inch rise. Is this the best plan of action or is their a better solution, one of my concerns is that it wouldn't be connected to the house.
Thanks Rudy
land308 is offline   Reply With Quote
Old 03-30-2011, 10:11 AM   #2
Experienced
Jackofall1's Avatar
Hello and welcome Rudy, the best DIY'r site on the web.
A precast step sounds like the easiest route to go on your problem.
Mark
Old 03-30-2011, 12:02 PM   #3
Learning Things Every Day
Jay 78's Avatar
Places that sell pavers will have a ton of options.
Under Construction
Jay 78 is offline   Reply With Quote
Old 03-30-2011, 02:31 PM   #4
steps
Thanks for the replys I hadn't thought of a pre cast concrete step. I will have to see how expensive that option is as i don't have alot of money to spend. How would one attach the steps to the existing concrete landing, would you attach a wooden ledger to the concrete landing and then rest the step on top of that?
Rudy
Replacing Section of Feed Line When replacing kitchen faucet??? spyboy Plumbing 5 03-21-2011 03:57 PM
Homeowner needs advice re: replacing existing hardwired under cabinet lighting bombacho Electrical 4 02-27-2011 08:57 AM
Replacing old galv irrigation pipe tns1 Plumbing 8 09-11-2010 05:08 PM
Replacing Windows? Kyle Remodeling 13 12-17-2009 08:03 PM
Replacing windows in a Bedford Stone home tim_the_toolman Building & Construction 6 12-02-2008 08:27 AM
