Replacing Old Weighted Window Options - Carpentry - DIY Chatroom Home Improvement Forum
Old 09-29-2008, 03:36 PM   #1
Rewards Points: 133
Replacing old weighted window options
What are my options for replacing the old weighted windows from 1939 that are in my house?
There are 13 double hung, 1 fixed, and 1 large one with sliders at either end in the kitchen.
Would it be a job I can tackle myself with help (mechanically inclined) or should I leave it to professionals ($$$)?
jimmyfloyd is offline   Reply With Quote
Old 09-29-2008, 05:31 PM   #2
Rewards Points: 562
Depending some on what else is involved. What kind of siding is on house? IF your planning on replacing that too, use a new construction window with nailing fins. IF you dont want to mess up any outside and inside finishes,,,use replacement windows. Replacements are generally more expensive. and single hungs are more energy effiecient than double hungs but harder to wash. Are ALL the windows easy to access fom outside?? for washing?Any second story windows avoid the tall ladder. I dont like casements because of hardware failures(try to buy replacement parts for anything 20 years old) YOUR the boss but think long down the road. IF your old windows rattles as bad aas mine did,,yes replace them... Make sure you properly insulate the cavity where the weights are,,otherwise its a drafty hole.
4just1don is offline   Reply With Quote
Old 09-29-2008, 08:34 PM   #3
Rewards Points: 6,652
There are replacements, that when you remove the Window Panels, they will slip in. Only drawback is, you will have to fill the cavities that the weights where in with Insulation. Plus side is, no heavy construction, and you keep the old look of the Window Frames.
Old 09-30-2008, 06:06 AM   #4
Rewards Points: 264
Marvin makes a replacement kit for this kind of job. They call it Tilt Pac. They work well and are pretty easy to diy if you have a little skill and patience. The kit comes with jambs and sash. When you are done you have a spring loaded jamb and tilt windows. Marvin sells some high end(=expensive) windows, but I don't remember if the Tilt Pacs are as costly as their premium stuff.
7echo is offline   Reply With Quote
Old 09-30-2008, 07:30 PM   #5
just wanted to add, it could be my thick head but took me a bit to understand how to measure for the replacement windows. once ordered, they frown about taking them back. and as others said, insulate the cavity, I didn't have the weights but had space there.
DUDE! is offline   Reply With Quote
Replacing window sash with rotten bottom jandrew Carpentry 3 08-31-2008 04:02 PM
Replacing a window in a foundation wall? Marlin Carpentry 14 11-04-2007 09:21 AM
Replacing aluminum window with a vinyl one? Doug Crf Building & Construction 2 04-23-2007 04:49 AM
Replacing a Window with a French Door gtruji Building & Construction 1 07-31-2006 05:27 PM
