#1 |
Replacing Newel Post
Hello. I am trying to replace the stairs railings on the second floor but I am not sure how to remove the existing newel post. It seems to go below the subfloor. Can I cut it flush with the subfloor and install the new one on top?
#2 |
What's wrong with the old one?
PS You do know your missing a base cap on those skirts, right? |
#3 |
STAFF
That post goes below decking or it was notched see the post at the end of the skirt board. It would be a lot better if you could install it down to the framing, surface mounted post aren't very sturdy. Since you have carpet it would be fairly easy to pull it back and cut the decking, install post and reinstall the decking.
New members: Please consider adding your location to your profile, it helps other members to give more accurate answers to your questions. To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. Jim |
#4 | |
Replacing Newel PostQuote:
Yes, I took the trims off in preparation of painting. They were nailed onto drywall only and I was able to pull them off without tools. But thank you for pointing it out. |
#5 | |
Previous owner had carpet wrap around the bullnose and we don't like it. Found the picture below using Google and would eventually like to have ours looking similar except there would be carpet on the steps. |
#6 |
STAFF
Sorry, I should have said underlayment and subflooring. That is the wood under the carpet, there is the layer directly under the carpet, (underlayment) and a layer of wood under the underlayment (subfloor)
| The Following User Says Thank You to BigJim For This Useful Post: | leungw (10-08-2012) |
#7 |
Stairguy
That post is notched below subfloor. You can see it just behind the skirt. If you can, take it out and cut you new newel with the same notch. If not you can probably use a surface mount newel kit. Like this one
#8 |
This user still active? I'd like to see how this came out.
#9 |
Does that newel post run down along the edge of the top riser?
#10 |
I'd say leave it as is. Under lying frame work may get in your way of simple removal and putting in another post. You may have to remove more flooring/underlayment/sheetrock/trim to remove that post and repair patch work will look terrible unless you commit yourself to replacing much of surrounding finish material.
That retrofit post kit does not work. It will work itself loose over time (I even tried lock tite on threads), and will be useless if you happen to hit a joint in the frame - and you probably will. ![]() I see nothing wrong with refinishing that post. The finish can be stripped, and if all you want is paint, not stain, you can rough up the current finish, prime with shellac primer and coat with a paint. Beat up wood will look much better with gentle sanding, filling up nail holes flush and paint, especially well done paint job. Use paint flow additive so it doesn't dry up on you too quickly. |
| Display Modes | |
| New posts and beams in crawlspace, post out of line | WillK | Building & Construction | 1 | 02-26-2012 10:56 AM |
| Adding additional newel post to staircase | flamtap | Carpentry | 3 | 06-24-2011 09:45 AM |
| replacing very warped 6 x6 post | Eric Horsley | Building & Construction | 2 | 10-09-2010 08:24 PM |
| Replacing wall with engineered Beam | pinkertonpv | Building & Construction | 4 | 01-15-2009 12:18 AM |
