-   -   replacing kitchen drawer slides (http://www.diychatroom.com/f14/replacing-kitchen-drawer-slides-168071/)
gerrybinder 01-02-2013 06:39 PM
Hi,
I've been doing a lot of research and visiting many of the sites recommended to buy replacement drawer slides. Maybe I am missing something...but my drawers are 18" deep and 20 3/4" wide. But I have frame face cabinets and the cabinet depth is 23". There is no clearance for side mount slides so I want to use undermount slides. There is 13/16" between the side of the cabinet and the drawer opening on each side. The drawer has about 1/4" total clearance. Can somebody tell me if I buy a 21 or 22" slide, will it work? Something like this:
http://www.outwatercatalogs.com/lg_d..._2012/page/281
or this:
http://www.wwhardware.com/kv-tt100-e...slide-kvtt100/
be ok?
Thanks so much.
Gerry
ddawg16 01-02-2013 07:48 PM
I hate side mount slides for kitchen drawers.....
You need to look at the specs on the slide....they will give you a min and max depth.
For a good reference, visit Rockler.com and do a search on drawer slides. Unless they are on sale, they tend to be expensive. But they have some good stuff.
Also do a search on self closing slides.
The under mount slides I have used had a bit of built in 'slop' in them....in other words, one side was fixed on position, but the other side gave you about 1/8th to a 1/4" of variation on position.
oh'mike 01-02-2013 09:22 PM
Search for Woodworking Supplies at Woodcraft.com
Woodworking Tools Supplies Hardware Plans Finishing - Rockler.com
Here a a couple of links----
gerrybinder 01-03-2013 06:45 AM
Hi and thanks for responding...guess I was not clear...let me try this...if I buy a 21 inch slide to fit the cabinet, can I still use my existing 18 inch drawers?
Thanks again.
oh'mike 01-03-2013 07:17 AM
Yes--you can use any size drawer you wish----the rails need to be sized for the cabinet box---as to the drawers---any depth will attach to the rails.
gerrybinder 01-04-2013 12:06 PM
hi oh'mike
many of the slides i have seen say not for retrofit or the drawer must be built to spec. do you know of a specific slide that can be used for retrofit and that could accommodate any size smaller drawer? Thanks again and sorry to be pesky,
oh'mike 01-05-2013 07:24 AM
With a retro fit--you need to just see what will work---no easy secret----you will need to know the height --distance--that the drawer bottom is above the face frame opening---
ddawg16 01-05-2013 10:08 AM
Is there a Rockler store near you?
If not, at least try their web site....lots of good info.
