Replacing Frontdoor Sill - Carpentry - DIY Chatroom Home Improvement Forum
Old 04-19-2011, 02:26 PM   #1
Replacing Frontdoor sill
Hi All-Having trouble posting picture so will describe problem....front door has windows on each side and sill runs under the whole thing ...it is a wooden sill and is rotting (it has been repaired with putty before now needs to be replaced......I am wondering if the sill can be cut and replaced on each side of the door and under door ??? or does the whole font door and side windows have to be taken out? I will try pic again..
Armand is offline   Reply With Quote
Old 04-19-2011, 02:53 PM   #2
A "Handy Husband"
rjniles's Avatar
Rewards Points: 4,034
If the sill under the sidelights (windows) is not rotten, I see no reason not to cut the sill below the door only and replace. Be warned that once the sill is out you may find that there is sub floor damage to repair before you install a new sill.
Coastal South Carolina
Old 04-19-2011, 03:32 PM   #3
Rewards Points: 5,336
I'd remove the entire unit from the opening. If the sill is rotted the subfloor and possibly the floor and rim joists are too.
If you are not experienced with doing this, buy some plywood and 2x4's ahead of time to close up the opening in you can't complete it in a day.
Ron
Old 04-19-2011, 05:18 PM   #4
front door sill replacement
the sill under windows on side is also rotten ....
Old 04-19-2011, 05:29 PM   #5
A "Handy Husband"
rjniles's Avatar
Ditto what Ron said, pull the whole unit and make the repairs on the sub floor and framing. Install a new one piece cell on the door/ sidelight unit and reinstall.
Replacing Section of Feed Line When replacing kitchen faucet??? spyboy Plumbing 5 03-21-2011 03:57 PM
Homeowner needs advice re: replacing existing hardwired under cabinet lighting bombacho Electrical 4 02-27-2011 08:57 AM
Replacing old galv irrigation pipe tns1 Plumbing 8 09-11-2010 05:08 PM
Replacing windows in a Bedford Stone home tim_the_toolman Building & Construction 6 12-02-2008 08:27 AM
