Go Back   DIY Chatroom - DIY Home Improvement Forum > Home Improvement > Carpentry
Old 04-06-2006, 02:14 PM   #1
Replacing floor framing
I am restoring a 125 year old brick home. The ground was leveled off and the brick walls built on the ground - no footers/concrete foundation. The first story floors are completely rotted away. There is at most 22" of space between the dirt and the bottom of the door frames -22" being the distance I fell before hitting solid ground ;0)
The first room I want to tackle is 12'x14'. What would be the best approach to building a floor back? Keeping in mind there's nothing along the ground at the walls except the walls themselves. Would I set block up against the bricks to set girders on? Also, with the limited amount of space, what size joists and girders and at what spacing? I went to get the building permit but where I'm at (way out in the county in TN) the only permit/inspections required is for new structures, exterior additions (porch/deck/garage), new electrical and new plumbing. So it won't be inspected but I want to do it right regardless. The brick were all handmade so the interior bricks are pretty fragile, don't think I could actually anchor anything to them. Any advice is appreciated.
Auntnana is offline   Reply With Quote
Old 04-21-2006, 11:58 PM   #2
I think if it were me doing it i would come in about 2 feet from outer opposite walls and dig a footer, when set would set 2 rows of block then fit a base plate on which to set my floor joists that way you wouldnt be damaging the brickwork but would have a secure floor. Of course anchor bolts fitted in the block construction.
lxdollarsxl is offline   Reply With Quote
Replacing Disc Brakes On 91 Toyota Corolla bobo Automotive Repairs 4 07-03-2007 07:31 AM
Replacing "Aluminum Flared" Windows? bahaisamurai Building & Construction 6 06-07-2007 11:23 AM
Replacing a Window with a French Door gtruji Building & Construction 1 07-31-2006 06:27 PM
Replacing 100 yr old windows Minden General Discussion 3 07-11-2006 12:58 PM
Replacing Roof Boards joedadog Roofing 12 05-14-2006 11:10 AM
