Go Back   DIY Chatroom - DIY Home Improvement Forum > Home Improvement > Carpentry
Old 05-25-2007, 02:51 PM   #1
Question
Replacing facia board
I am looking to to replace some rotting facia board around the home and add a furring strip just below the edge of the shingles.
Is it ok to use pine for the furring and facia as long as it is properly primed ands painted?
Also, if the shingle will extend 1/2" - 3/4" past the furring strip, do I still need to have the galvinized flashing in place?
Thank you in advance for any responses.
Matt
mattflytx is offline   Reply With Quote
Old 05-25-2007, 03:40 PM   #2
Lic. Builder/GC/Remodeler
AtlanticWBConst.'s Avatar
For the fascia material: Yes, you can use Pre-primed pine.
Tip: Prime the ends (after cutting) too....prior to install and nailing.
You must mean OVER the furring strip. ?? I am not sure I understand what you are talking about.
...If you are referring to ground molding (1"x1" trim that is placed under the inside edge of the fascia). This is made of Fingerjointed cedar.
.....as far as using flashing: Do you mean a galvanized drip cap? or do you mean something else?
- Build Well -
Old 05-25-2007, 04:51 PM   #3
Ok, maybe furring strip is the wrong term. Currently I have gutters attached to the front of the facia board. I will remove the gutters and only reattach in critical areas. I have noticed on some of the neighborhood houses that they have a 1" x 2" molding strip attached to the front of the facia right beneath the overhang of the shingles. If I were to add this peice and the overhang of the shingle would still be about 1/2" to 3/4", would I still need to have the drip cap (flashing that I refered to earlier)?
Do people use pressure treated lumber on eves and overhangs?
Old 05-25-2007, 06:19 PM   #4
Again, you lost me.
Are you speaking about the molding strip or the trim board attached under the soffit, against the house?
Example of Trim Board with a strip of 'bed molding' at the soffit:
Example of 1/4 round molding strip at the soffit:
Picture of cedar shake 'shingles' siding with base shoe style band strip at soffit:
Is it one of these styles or different?
No, never.
- Build Well -
Old 05-25-2007, 06:23 PM   #5
Ok, I think I figured out what you are speaking about.
You are speaking of the shadow board that is also shown in one of the pictures I posted (that is what we call them, other builders may have a different name for it).
Refer to picture #2 that I posted.
Looking at those pictures helped me to understand what you were referring to. You were speaking of the 'roof shingles', and I thought you were talking about 'siding shingles'.
These are pre-primed pine. You can buy these in different 'quality levels'.
You will most definitely need an aluminum drip cap over that piece of trim. You can get these in different widths and different colors.
- Build Well -
Old 05-25-2007, 09:05 PM   #6
Thank you much for your help.
One last question: what type of lumber do you use for the soffit?
Old 05-25-2007, 09:11 PM   #7
That depends on if you are trying to match an existing soffit material.
Modern materials are 3/4" Pre-primed pine.
Example: If you look at the second pic I posted, you will see the soffit with 1x4 Pre-primed pine board, then a strip soffit vent, then another 1x4 Pre-primed pine board. The widths are dependant on the actual width of the soffit on the existing home or the architect's design.
- Build Well -
Old 05-25-2007, 09:23 PM   #8
My overhang extends a little less than 2' and they used 1/4" thick material with 6" x 12" vents about every 10'. Most of the soffit wood is in good shape so I will just match with primed pine of the same dimensions.
Thank you.
Old 05-25-2007, 10:17 PM   #9
Thank you.
1/4" material is probably 1/4" sanded plywood.
- Build Well -
Old 05-25-2007, 11:00 PM   #10
Log-Style Home Contractor
North Country's Avatar
When doing plywood soffits up in Northern Michigan, 3/8" No-Groove Fir panels are often used. This may be what you are refering to in the 1/4" plywood. Otherwise 3/4" Tongue and Groove Cedar is also a popular option among log homes.
North Country is offline   Reply With Quote
Old 05-26-2007, 08:46 AM   #11
Who said anything about this being a log home?
- Build Well -
Old 05-26-2007, 09:22 AM   #12
Nobody said anything about this being a log home. I didn't mean to imply that I assumed it was. I was just giving examples of wood soffitting. The 3/8" is quite popular among T1-11, cement and vinyl sided homes, whereas the t&G is quite often limited to log style construction.
Old 01-08-2008, 10:17 PM   #13
I'm doing somewhat of the same type job. I plan to post pictures up on here of my individual eaves/soffits, or what actually is the sorry excuse for them. I recently purchased my home (during the last six months) and there are no gutters where there should be, VERY little space for an overhang at other spots, and I can see daylight in the back corner and header portion of my garage rear wall. I GOTTA post the photos so you can see. Just let me know, should I start my own thread, I don't wanna hijack this one on the guy....Thanks all!!
mudpaws is offline   Reply With Quote
Old 01-09-2008, 07:51 AM   #14
You should start your own thread. It's the polite/correct thing to do, and you will get more alot more responses.
Welcome to the site.
- Build Well -
Old 01-09-2008, 09:50 PM   #15
Matt
The previous rotting problem was probably due to the lack of drip cap or drip edge. In your case with only 1/2 - 3/4 of shingle overhang, I'd suggest using 1x2 drip edge (L-shaped) rather than D-style which would leave your shingles flush with the drip edge.
pavola is offline   Reply With Quote
More On This Topic
Learn how to remove side trim board to remove the siding on you house from a professional contractor in this free DIY home improvement video. Read More »
Pictures can illustrate points during public speaking in ways that words sometimes cannot. Use pictures in successful public speaking with tips from an award-winning speaker in this free communication video. Read More »
Vision Board Pictures
Vision Board Pictures by Laura Cohn
Finding pictures for a vision board can be very fun and should relate to your vision board topic. Learn more about picking vision board pictures with expert tips in this free craft video. Read More »
You can attach your vision board pictures with either glue or tape. Learn more about attaching the pictures for your vision board with expert tips in this free craft video. Read More »
When painting a portrait, a reference picture will help with proportions. Use a reference picture when painting acrylic portraits with tips from an illustrator in this free art video. Read More »
Installing backerboard - replace particle board? salvop Flooring 9 08-13-2007 08:11 AM
Installing Soffit and Facia??? Vikeologist Roofing 3 11-15-2006 06:01 PM
Installing deck ledger board over foam board? RickT Building & Construction 5 11-06-2006 11:50 PM
facia repair and gutter boman47k Carpentry 2 09-11-2006 08:06 AM
Ruud a/c control board replacement ? kourso HVAC 1 07-20-2006 10:33 PM
Copyright ©2000 - 2010, Jelsoft Enterprises Ltd.
