Replacing Drop-in With Slide-in Range Will It Fit? - Carpentry - DIY Chatroom Home Improvement Forum
Old 01-07-2008, 01:47 PM   #1
Replacing Drop-in with Slide-in Range will it fit?
I ordered a Frigidaire 30 slide-in #FES3555ES that will arrive in a week, to replace a Westinghouse drop-in # KD220GDD2 (could be KD220G002) I pulled the drop-in out some to see what I would have to do to the bottom and found out my cabinet opening as well as the cut out is only 29 3/8 not 30 . Will the new slide-in fit?
Tim
TLT01 is offline   Reply With Quote
Old 01-07-2008, 05:12 PM   #2
Rewards Points: 5,336
Go to the Frigidare website and get the exact width of the unit you bought. If it's larger then 29 1/4, the opening will need to be made larger.
Ron
Old 01-07-2008, 08:39 PM   #3
Frigidaire only gives that the cut out should but 30" not the real width.
Old 01-07-2008, 09:23 PM   #4
Thanks Ron
I found the Frigidaire site you were talking about with the installation instructions and on page 8 & 9 it shows how to install in 29" opening
with optional kit.
gas range swap kenny11876 Appliances 2 02-20-2008 09:31 PM
Drop In Range Hook-Up mickey45 Electrical 1 04-08-2007 10:29 PM
Electric Range Wiring manhattan42 Electrical 11 07-05-2006 06:03 PM
Home, home and the range! ...A dimensional query. Hushpuppy Carpentry 4 05-26-2006 07:23 PM
Replacing Stove Top with Range the.vicster Electrical 3 02-23-2006 06:12 PM
