Replacing Door Jam - Carpentry - DIY Chatroom Home Improvement Forum
Old 10-09-2010, 05:24 PM   #1
replacing door jam
What size nail should I use 2 1/2" or 3" when replacing a door jam?
Art Johan is offline   Reply With Quote
Old 10-09-2010, 05:36 PM   #2
door jamb
what size nail should I use when replacing a door jamb, 2 1/2" or 3"?
Old 10-09-2010, 08:47 PM   #3
Ole Wood Worker
BigJim's Avatar
Rewards Points: 114
It really depends on how much extra space you have between your jamb and the frame work. I have seen, at times, where the frame was 3 inches wider than the door jamb and that makes quite a reach for shims and nails. If there is a lot of extra room between the frame and jamb I would nail some fillers straight to the frame before putting the jamb in the frame.
I have always preferred 2 1/2 inch personally as the 3 inch nails have more of a chance of run out or following the grain of the wood and curl back out of the wood. I am speaking of gun nails here.
One thing I always did was install a 3 inch screw under each hinge as it will really help hold the frame in place.
New members: Please consider adding your location to your profile.
He is no fool who gives what he cannot keep, to gain what he cannot lose.
http://www.woodworkingtalk.com/forum.php
Jim
BigJim is online now   Reply With Quote
Old 10-10-2010, 12:29 AM   #4
jlhaslip's Avatar
Rewards Points: 384
Interior door? or Exterior?
Nominal 1" (3/4") jamb? or 2" (1 1/2" rabbeted)?
I have used up to 3 1/2" galvanized casing nails on thicker exterior jambs.
Originally Posted by Bud Cline View Post
Go ahead and apply for a variance, those guys at City Hall can use a good laugh.
jlhaslip is online now   Reply With Quote
Old 10-10-2010, 01:46 PM   #5
replacing jamb
THANK YOU very much for your help. This is a door from the garage to the kitchen entry. You ahve been very helpful. ART
Replacing old galv irrigation pipe tns1 Plumbing 8 09-11-2010 05:08 PM
Replacing Windows? Kyle Remodeling 13 12-17-2009 08:03 PM
Replacing sliding patio door problems marlinpuppy Building & Construction 2 02-22-2009 09:11 PM
Replacing windows in a Bedford Stone home tim_the_toolman Building & Construction 6 12-02-2008 08:27 AM
