Go Back   DIY Chatroom - DIY Home Improvement Forum > Home Improvement > Carpentry
Old 09-04-2007, 04:09 PM   #1
replacing carport supports with 4x4 pt posts
I am screening in my carport and i am replacing the rusty wrought iron supports with pt 4x4s as corner posts of the screened area on the front only (the back is a brick wall). building inspector says that i need to anchor the posts to the concrete. whats the easiest and cheapest way to do this? the roof will be sufficiently supported all around so i just want to meet code and move on>>>hopefully no cocrete cutting and re-pouring.
timmorin@clearchannel.com is offline   Reply With Quote
Old 09-04-2007, 04:17 PM   #2
post achors. there are different types, so ask which one is acceptable.
Jeekinz is offline   Reply With Quote
Old 09-04-2007, 04:54 PM   #3
so that's it? obviously drill into the concrete and secure the anchor and then secure to post, right? thanks!
Old 09-04-2007, 04:58 PM   #4
Yeah, there are some models that raise the post up off the cement to keep it away from water.
Like I said, ask the inspector which one he/she reccomends you use.
Old 09-04-2007, 05:00 PM   #5
I will, thanks for the quick reply.
Old 09-04-2007, 05:27 PM   #6
I think it's the one that's off the ground a bit. what does that one look like?
Old 09-04-2007, 07:27 PM   #7
Lic. Builder/GC/Remodeler
AtlanticWBConst.'s Avatar
Looks like this:
- Build Well -
Old 09-10-2007, 01:19 PM   #8
I now have to anchor the top of all of my screen porch posts. what's the cheapest, easiest to install product to use for this. I have an existing roof structure...it's a carport.
replacing porch supports smallcrpt Building & Construction 11 07-03-2007 09:03 PM
Installation of pergola posts HDelahay Landscaping & Lawn Care 13 10-11-2006 07:46 AM
Framing a carport on a detached garage nomagic Carpentry 3 05-04-2006 11:43 PM
Moving Header Supports Star Building & Construction 3 09-25-2005 01:50 AM
45 Degree balcony supports rickr01 Building & Construction 5 09-12-2005 12:10 PM
