-   -   replacing carport supports with 4x4 pt posts (http://www.diychatroom.com/f14/replacing-carport-supports-4x4-pt-posts-11269/)
timmorin@clearchannel.com 09-04-2007 03:09 PM
I am screening in my carport and i am replacing the rusty wrought iron supports with pt 4x4s as corner posts of the screened area on the front only (the back is a brick wall). building inspector says that i need to anchor the posts to the concrete. whats the easiest and cheapest way to do this? the roof will be sufficiently supported all around so i just want to meet code and move on>>>hopefully no cocrete cutting and re-pouring.
Jeekinz 09-04-2007 03:17 PM
post achors. there are different types, so ask which one is acceptable.
http://www.framingconnectors.com/ima...oducts/PBC.jpg
timmorin@clearchannel.com 09-04-2007 03:54 PM
so that's it? obviously drill into the concrete and secure the anchor and then secure to post, right? thanks!
Jeekinz 09-04-2007 03:58 PM
Yeah, there are some models that raise the post up off the cement to keep it away from water.
Like I said, ask the inspector which one he/she reccomends you use.
timmorin@clearchannel.com 09-04-2007 04:00 PM
I will, thanks for the quick reply.
timmorin@clearchannel.com 09-04-2007 04:27 PM
I think it's the one that's off the ground a bit. what does that one look like?
AtlanticWBConst. 09-04-2007 06:27 PM
Looks like this:
http://i28.photobucket.com/albums/c2...T/DSC00613.jpg
timmorin@clearchannel.com 09-10-2007 12:19 PM
post anchors - top
I now have to anchor the top of all of my screen porch posts. what's the cheapest, easiest to install product to use for this. I have an existing roof structure...it's a carport.
