Replacing Bathroom Wall Tiles - Carpentry - DIY Chatroom Home Improvement Forum
Old 11-07-2010, 10:51 AM   #1
Post
Replacing bathroom wall tiles
We are replacing several broken wall tiles in the bathroom. We have removed the broken tiles and need to remove the thinset (?) that was left behind. some of the broken tiles are in the middle of other good tiles, so removing the sheetrock is not really a viable solution. Suggestions as to the best/easiest way to remove the stuff left behind when we removed the tiles?
Thanks!
Shutterbug7 is offline   Reply With Quote
Old 11-07-2010, 11:43 AM   #2
ccarlisle's Avatar
Fein Multimaster oscillating tool - or equivalent - with the appropriate blade - or hammer+1" cold chisel...
“The average American woman is about 25 pounds heavier than she was in 1960...Recognizing obesity as a disease will help change the way the medical community tackles this complex issue that affects approximately 1 in 3 Americans,”
ccarlisle is offline   Reply With Quote
Old 11-07-2010, 01:42 PM   #3
Tileguy
Bud Cline's Avatar
Rewards Points: 558
Any metal scraper or chisel will remove the old adhesive.
XXX
Old 11-07-2010, 06:29 PM   #4
Cool; thank you both.
Old 11-08-2010, 10:04 AM   #5
yes just take your time or you will cause more damage, it can be difficult after a long day
Bobby_B is offline   Reply With Quote
Tags
bathroom tiles , removing thinset , removing tiles
Basement Concrete Wall Framing Against Stairs Epicsoccer Remodeling 7 01-13-2013 03:11 PM
WET concrete wall under TOP floor bathroom window---how to stop? Dyoung Building & Construction 8 02-13-2010 10:14 PM
How to diagnose problems with wall kahlan General DIY Discussions 5 10-22-2008 09:18 AM
Raising Doorway Height (load bearing?) treefrog Building & Construction 6 02-25-2008 09:11 PM
Replacing A Few Tiles On Shower Wall EDENO Remodeling 1 12-11-2006 11:25 AM
