Go Back   DIY Chatroom - DIY Home Improvement Forum > Home Improvement > Carpentry
Old 10-19-2009, 05:55 PM   #1
Default replacing basement bearing wall
I am remodeling our basement and want to open a bearing wall to create a clear span. The current wall consists of 8'6" tall 2x6s. The floor above is the mainly open flooring with a column supporting a cantilevered corner of the second floor hall. I would like to use laminated beams. The open span will be 16'. Does anyone have any idea what size beams I should use? I can use 3 beams up to 14" in depth if necessary.
roger843 is offline   Reply With Quote
Old 10-19-2009, 07:24 PM   #2
Civil Engineer
I assume you are referring to glue laminated beams (Glulams). You can probably get the beams sized by the supplier. You will need to bring in a dimensioned sketch plan showing the clear span required, and the location of the column you plan to support. You will also need a detail of the proposed means of connecting the Glulams to the foundation, maybe bring in a few photos. The supplier needs to be familiar with your local codes, since you are probably going to need a permit for this, and local code will determine the floor loading the beam needs to support.
Old 10-19-2009, 08:36 PM   #3
Many codes would require a stamped engineered design for this kind of thing. Poke around with your supplier and with your local code and see if an engineer is required, it can be surprisingly reasonable for a simple design.
Salem747 is offline   Reply With Quote
More On This Topic
Graphic designers and artists who pursue freelance opportunities need to understand the value of their work. The final value of a poster or web page is only one consideration for freelancers trying to price graphic design services. It is important for... Read More »
Wakeboard towers add value and style to your boat. Not only are they practical for holding wakeboards, but they are also great for mounting speakers and other accessories. Besides figuring out how to build it yourself, there are several options available... Read More »
Crimping Beaded Earrings
Crimping Beaded Earrings by Expert Village
Now that we've crimped the wires, and if you notice I had cut off the excess, and here's some excess silver. This is sterling silver. You can save all your little scraps and you'll be able to sell them at a jewel or repair shop and every little bit of... Read More »
How to Laminate a Name Tag
How to Laminate a Name Tag by Expert Village
Now I have my guest name tags all ready in the little sleeves, luggage tag sleeves and they are ready to go through the laminator. Now I've had my laminating machine on for about 15 minutes so it'll heat up and it has a little ready light that indicates... Read More »
Moving Load Bearing wall in Basement iqkhn Remodeling 4 04-05-2009 06:53 PM
Bearing Wall - Finding a Contractor imgetinold Building & Construction 1 03-23-2009 11:21 PM
Running duct over bearing wall jhillman HVAC 10 03-23-2009 04:54 PM
subpanel mounting on concrete basement foundation wall bulk88 Electrical 12 03-10-2009 03:38 PM
Bearing wall, HELP me please jamiedolan Building & Construction 7 11-03-2008 01:33 PM
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
