-   -   Replacement Windows? Asbestos Shingles? I have NO CLUE! (http://www.diychatroom.com/f14/replacement-windows-asbestos-shingles-i-have-no-clue-84326/)
Evil Scotsman 10-19-2010 08:10 AM
Long story short, the house has ORGINAL single pane ALUMINUM frame SLIDER windows from the 60's. (home inspector said they were no good the day after they were installed) My wife inherited the house and we want to do the work BEFORE we move in. I would PREFER to install the windows myself, (my brother has experience with replacing windows I do not) and save the money. The issue is I want to replace with vinyl double hung or casement, not sliders. How would I cap/finish the windows on the outside with asbestos shingles?
Thank You
Michael Thomas 10-19-2010 10:53 AM
Originally Posted by Evil Scotsman (Post 519413)
How would I cap/finish the windows on the outside with asbestos shingles?Thank You
Installation would be much like that for retro-fitting a window into modern fiber-cement siding.
Hopefully, the shingles are installed over a weather resistant barrier (WRB), likely (given the age of the building) "builders felt" - this served somewhat the same purpose as a more modern WRB such as house-wrap ("Tyvek")
If so, you would install a "Z" flashing under the WRB and out over the head trim on the windows. It would also be a very good idea to install a pan flashing at the bottom of the window and out over the siding. (Some replacement windows have "self-flashing" features which according to the manufacturers makes a "Z" flashing unnecessary if the windows are installed according to the manufacturers instructions - many experienced installers are skeptical about the long-term performance of this arrangement in retrofit installations, and prefer to also install a head flashing as a "belt and suspenders" approach.)
You can get a general idea of the procedure from the right-hand Fig 3. here:
http://www.jameshardie.com/pdf/insta...epanel-hz5.pdf
And from this article:
http://www.finehomebuilding.com/PDF/Free/021197054.pdf
except that you will be working with the existing WRB rather than the house-wrap shown in the article.
_________________
Cutting the asbestos siding in such a way that the asbestos does not become friable is another issue entirely.
Evil Scotsman 10-19-2010 01:01 PM
Thanks Mike, I appreciate you answer AND the links! I think you just convinced me, (as long as the price is OUTRAGEOUS) I will leave that to the pros!
Cheers
