Replacement Entry Door Is Smaller - Carpentry - DIY Chatroom Home Improvement Forum
Old 12-24-2010, 08:44 AM   #1
replacement entry door is smaller
Contractor says replaced entry door is smaller. The metal jam where the lock goes should have wood support. There is no cap in the hollow space where the lock mechanism should go when the door is shut. I can reach down into the hole where the lock should go. (1)Shouldn't there have been additional wooden support under that metal jam? (2)At the bottom of the door entry, there was supposed to be a metal extension to make the door entry airtight. Subcontractor claims that the tiles in front of the door is almost level with the jamb and therefore they can't fix it. You can see light and air at the bottom. Having read your site, I can see that it probably can be fixed.
france is offline   Reply With Quote
Old 12-24-2010, 10:07 AM   #2
Registered User
Termite's Avatar
A picture would help illustrate your problem, but from the description it sounds like your contractor did not finish the job. Hopefully you have not paid them yet. But yes, these issues can probably be rectified.
Old 12-24-2010, 12:59 PM   #3
Rewards Points: 5,336
You're not using standard terminology so it would really help if you posted photos of all the issues. Look at the photos before you post them to make sure they tell the story.
Ron
Changing Size of Replacement Window joside Remodeling 10 05-30-2012 04:46 PM
Replacement Windows Smaller Than Rough Opening stubits Remodeling 1 08-25-2010 06:19 AM
replacement entry door BlueBSH Building & Construction 3 07-21-2010 03:23 PM
Timing for rebuilding of side entry: Help! navi_jen Remodeling 0 06-16-2010 10:02 AM
Old 80" wood entry door replacement janralix Carpentry 5 08-18-2009 12:02 PM
