Go Back   DIY Chatroom - DIY Home Improvement Forum > Home Improvement > Carpentry
Old 08-02-2011, 02:01 PM   #1
Replace wood around door
Hello All,
I am looking to replace the moulding and flat wood (the vertical section with the light is on) I will be painting all the wood white. My question is what type of wood should I use? Is pine fine for the moulded pieces, if I oil prime all sides? And is plywood ok for vertical section? If so would it be A/B or a maple furniture grade?
Thanks in advance for the help.
David51st is offline   Reply With Quote
Old 08-02-2011, 02:54 PM   #2
Not so new
12penny's Avatar
I would use whatever the original builder used. Thats some beautiful detail...seems a shame to use inferior products.
Scratch off some paint and see what it is.
And whats the matter with it? Looks good from here.
12penny is offline   Reply With Quote
Old 08-02-2011, 03:22 PM   #3
Thanks for the feedback and kind words. I was plaining on saving the arched pieces, as I could never bend 2.75 full round oak that well. I guess the photo doesn't tell the whole story. The sides have been cut by "hacks" over the years. Whoever installed the lights and intercom cut away and replaced with several pieces of plywood, 1/4 inch to 3/4 inch. Nothing matches. The vertical moulding is chewed up and beyond repair. The wood directly around the door is brick mould that came with the door and does fill out to vertical sides.
My hope is to replace sides and door moulding. Also create a set of sunburst mullions for the arched glass over the door.
Old 08-04-2011, 09:44 AM   #4
You can't use an interior plywood in this exterior location. I wouldn't use plywood at all. What are the overall dimensions of these pieces? If they are thick and wide, you'd get better results from glueing up pieces of dimensionally stable wood to get a more stable slab.
Ron
B. Franklin 1759
Old 08-04-2011, 09:49 AM   #5
Not so new
12penny's Avatar
Exactly...I'd probably look at spanish cedar or maybe mahogany. Dont want to it again in a couple years.
Old 08-05-2011, 08:06 AM   #6
BUILDER / REMODELING CONT
buletbob's Avatar
AHHHH Spanish cedar Good choice. I DONT KNOW HOW FUSSIE YOU ARE. But if you are going to paint it and they are the sides why not look into AZEK PVC trim boards. they will last a life time. and is alot cheaper.
OSB Stronger than Plywood? Weathermaker01 Flooring 15 12-22-2012 10:06 AM
Leaking Door JaneD Windows and Doors 2 06-15-2011 09:22 PM
Pre-Hung doors - How to Hang Willie T How To Guides 23 01-28-2011 10:24 AM
louvered metal door to replace louvered wooden door norfolkgarden HVAC 5 12-19-2010 05:09 PM
Storm door parts? Wood core? Anything but the whole door... CoconutPete General Discussion 2 12-02-2010 01:39 PM
