| DIY Forum | DIY Blogs | Photos | Woodworking | Extreme How To | Advertise | Contact Us |
Previous Thread
Next Thread
More On This Topic
How to Make Doors Energy Efficient
by eHow.com
One area where homes are less energy efficient is around doors. Many older doors leak around their edges, and many others are simply not insulated enough to provide good energy efficiency. Making doors energy efficient is one of the most obvious ways to... Read More »
How to Replace a Car's Front Door Light Cover
by Expert Village
Hi, I'm Mark Blocker on behalf of Expert Village. In this segment of our interior lighting systems, we're going to cover installing the lens cover. As I pointed out, the cover is held on by four clips. Four plastic clips. And the older the car gets these... Read More »
Refinishing a Door Jamb Summary
by Expert Village
Watch conclusion for refinishing a door jamb in this free house remodeling video from an expert finish carpenter and experienced home inspector. Read More »
How to Seal Drafty Air Leaks in Your Home
by eHow.com
There are many areas in the average home that are subject to drafts and air leaks. Whether it's dropped ceilings and window frames or air ducts or furnace flutes, chilly homes in the winter are unfortunately the norm. Air infiltrates into and out of your... Read More »
How to Check Flat Tire Damage
by Expert Village
Hi! I'm Jeff Wong for Expert Village. Today we are going to learn how to change a flat tire. You want to access the damage that you occurred on your tire and know whether you need to replace the tire or the tire can be repaired by a simple patch. As you... Read More »
