Replace/repair Balcony Floor - Carpentry - DIY Chatroom Home Improvement Forum
Old 06-02-2012, 11:03 AM   #1
hohadcr's Avatar
Rewards Points: 316
replace/repair balcony floor
Hi, Please see attached pic.
I need to replace/repair the damaged floor of my front balcony.
How do I go about it?
The iron fences and pillas are screwed on to the floor boards, do I try to unscrew them and try to insert the new floor boards underneath?
replace/repair balcony floor-img_20120531_112947.jpg   replace/repair balcony floor-img_20120531_112955.jpg
hohadcr is offline   Reply With Quote
Old 06-02-2012, 11:23 AM   #2
Retired Cabinetmaker
woody4249's Avatar
Rewards Points: 156
I assume that the pillars are supporting some kind of roof structure and therefore hold weight. Providing the joists are sound underneath, I would suggest removing a section of boards at a time starting at the top of the steps with a suitable threshold board. Depending on the distance between each pillar, use a 2x4 with a brace at the top as a "Preacher" to support the roof as close to the pillar as possible allowing enough access to work. Remove about 2ft at a time so that you can still work on the existing boards. Remove the screws to the railings as you go and replace with galvanized or stainless as you go. With a project like this safety is a concern, so only remove a few boards at a time. Material should be 5/4" pressure treated or composite boarding, again using galvanized or stainless steel screws.
If you have extensive damage to the structure other than what you can see.........re post this and we'll come up with a new plan.
Last thing.....give your neighbours the heads up when your working up there,
"I'm not as green as I am cabbage looking"
woody4249 is offline   Reply With Quote
Floor joist replacement and reconfiguration WillK Carpentry 2 09-01-2011 08:01 AM
Dryer duct hole thru band joist & floor joist justplumducky General DIY Discussions 12 10-05-2010 12:31 PM
2nd floor air flow/pressure fgillis HVAC 7 02-24-2009 04:58 AM
Old old linoleum, can it take paint? molamola Painting 23 11-11-2008 06:32 PM
Carpet in the basement Packer Backer Flooring 16 11-03-2008 11:19 PM
