Replace Old Treads With Oak Treads - Carpentry - Page 2 - DIY Chatroom Home Improvement Forum
Old 03-03-2009, 06:11 PM   #16
Old School
Willie T's Avatar
Gosh, I haven't seen a boxed staricase in years. Whole different ballgame. I thought you were saying the bottoms of the treads had been dado grooved, and I was having a hard time figuring why they'd do that.
Willie T
Old 03-03-2009, 06:17 PM   #17
Any opinions on this ?
http://www.stairsupplies.com/eng/pro...rs/treads/8073
Nice to have a 'fall back' plan
Lew_B is offline   Reply With Quote
Old 03-03-2009, 06:29 PM   #18
Rewards Points: 272
When I went to site it does not state that the 1/2" oak is a solid or a ply, need to check more on that.
fixrite is offline   Reply With Quote
Old 07-21-2010, 06:32 AM   #19
Following this thread now.♠
RuthGeitgey is offline   Reply With Quote
Old 07-21-2010, 09:55 AM   #20
Ole Wood Worker
BigJim's Avatar
Rewards Points: 288
ruler10, if you plan to us a circular saw to cut your treads you may want to cut them from the bottom of the tread as they will not splinter as easily. Without a guide for the circular saw it will be very hard to cut a dead straight line.
As for using a nail gun, you shouldn't have any problems if you use a good trim gun. I always glued and nailed the riser to the back of the tread to keep them from squeaking.
While I lived in West Tennessee I could get a construction adhesive called "F26" which looks kinda like Liquid Nails but it is way tougher than Liquid Nails, that is what I used to glue the treads down and the tread to riser. Where wood touches wood, there should be glue or the tread can squeak.
Jim
BigJim is offline   Reply With Quote
Replace door sill = Need new door? NNJGUY Carpentry 23 09-01-2009 01:54 PM
repair or repalce stairway treads? mariad Building & Construction 4 11-03-2008 08:08 PM
Sister or Replace Floor Joists brando1118 Carpentry 25 10-26-2008 08:43 PM
Pennsylvania Bluestone Treads rjordan392 Building & Construction 4 03-30-2008 10:37 PM
Replace main panel? And lots of other ?s Bcoleman6 Electrical 13 01-22-2008 09:40 AM
